Connect clients ​
Point a client at Model Gateway instead of a provider to route its requests through your routes and policies. Each client needs an access key and the route ID of a route the key can use.
Connect Anthropic-compatible clients ​
Model Gateway only accepts the access key as a bearer token in the Authorization header. Anthropic clients send credentials in an x-api-key header by default, so configure the client to send a bearer token instead. Set the model to a route ID.
Replace <model-gateway-host> with the host from the URL shown in the Access key generated dialog, for example https://ai.workato.com.
