AI gateway collection ​
An AI gateway collection exposes endpoints to LLMs, GPTs, or other AI applications. This setup enables AI agents to take actions on your behalf using secure, authorized requests. Refer to AI gateway for more information.
COLLECTION TYPES
Refer to Collection types to determine whether an API proxy collection, API recipe collection, SOAP API recipe collection, or AI gateway collection fits your use case.
Prerequisites ​
Complete the following before you create an AI gateway collection:
Create an AI gateway collection ​
Complete the following steps to create an AI gateway collection:
Go to Platform > API platform > API collections.
Click + Create new collection.
Use the What type of collection would you like to create? drop-down menu to select AI gateway collection.
Select AI gateway collectionSelect AI gateway collection
Use the Select AI model provider drop-down menu to select an AI provider. This setting optimizes your OpenAPI specification and prompt formats for the selected provider.
Use the Choose a configuration type drop-down menu to specify the configuration you plan to use for your recipe collection:
  • Use existing recipes: Select the Recipe folder from the drop-down menu. Workato maps each API recipe in this folder to a new endpoint.
  • Import OpenAPI Specification: Upload a JSON or YAML OpenAPI 3.0 specification file, or enter the URL of the specification.
Choose configuration typeChoose your configuration type
Go to Customize endpoints and select the checkbox next to each endpoint you plan to add to the collection.
Optional. Select Edit details next to an endpoint to configure its settings:
Select the HTTP method to use for the endpoint.
Customize AI gateway collection endpointsCustomize AI gateway collection endpoints
Enter an Endpoint name.
Define a path for the endpoint in the Endpoint path field. This path is appended to both the AI and target base URLs. It can include path parameters. Ensure that you follow the endpoint path guidelines.
Enter an Endpoint description.
Required when you toggle Customize timeout. Customize the time that a request is given to complete in the Request timeout field. The default value is 30 seconds and the maximum value is 240 seconds.
Enable Schema validation to validate all requests made to this endpoint.
Enforce additional authorization logic using formulas using the Request authorization field.
Enable response caching to improve performance in the Cache response field.
Required when Cache response is enabled. Use seconds to specify how long to store a response in cache before it's refreshed or deleted in the Time-to-live period field. The maximum value is 3600 seconds.
Go to Set collection details and enter the following information:
Enter a Collection name for the AI gateway collection.
Enter a Version. Use a unique identifier between 1–10 characters. Workato treats collections with the same name but different versions as separate objects.
Optional. Enter a Description for the AI gateway collection.
Set collection detailsSet collection details
Click Create collection.
Select a Next steps link or click View API collection.
View API collectionView API collection
