# AWS Inspector2
AWS Inspector (opens new window) is a vulnerability discovery service that automates continuous scanning for security vulnerabilities within your Amazon EC2, Amazon ECR, and Amazon Web Services Lambda environments.
# Prerequisites
Ensure you have an active AWS account with the proper permissions to set up and manage AWS Inspector2 before using the AWS Inspector2 connector in Workato:
  • Enable Amazon Inspector: Ensure that Amazon Inspector is enabled for your AWS account. You can activate it in the Inspector dashboard of the AWS Management Console.
  • IAM Permissions: Grant the necessary permissions to users or roles that will manage and operate Amazon Inspector. Key managed policies include: AmazonInspector2FullAccess and AmazonInspector2ReadOnlyAccess.
  • Set up and Configure Amazon EC2: Ensure you have EC2 instances running in your AWS environment. Inspector 2 scans workloads such as EC2 instances and container images in the Amazon Elastic Container Registry (ECR).
  • Install Systems Manager Agent (SSM Agent): Install and configure the AWS Systems Manager Agent (SSM Agent) on all EC2 instances so that Inspector 2 can gather data. For supported operating systems, it is either pre-installed or needs manual installation.
  • Enable Resource Scanning: Configure which resources Amazon Inspector should scan:
    • EC2 Instances: Activate scanning for operating system vulnerabilities.
    • ECR Repositories: Ensure repositories are connected for image vulnerability assessments.
  • Review VPC Configurations: Ensure that network configurations (such as, firewalls, security groups) allow Amazon Inspector2 to access the required resources.
  • Service Quotas: Check your service quotas to ensure you have sufficient limits for scanned resources, findings, etc.
# Connection Setup
Workato supports the following types of connections to AWS Inspector2.
# Access key authentication
The AWS access key ID and secret are required for access key authentication. Go to AWS account name > Credentials > Users to find an existing user's credentials or create a new user.
Complete the following steps to establish a connection to AWS Inspector2 in Workato using IAM role authentication:
Install the AWS Inspector2 connector from the community library. Refer to the Install a connector from the community library guide for more information.
Search for and select AWS Inspector2 as your connection on the New Connection page.
AWS Inspector 2 Access key connectionAWS Inspector 2 Access key connection
Use the Auth type field to select Access key as the connection type.
Enter your app's Access key ID and Secret access key.
Provide the AWS inspector Region, such as us-west-2.
# IAM role authentication
IAM roles provide temporary credentials for accessing AWS Inspector without long-term access keys. This method is recommended for applications running in AWS environments like EC2, Lambda, ECS, or EKS.
Use the Auth type field to select IAM Role as the connection type.
Enter the provisioned IAM role's ARN in the IAM role ARN field.
AWS Inspector 2 IAM role connectionAWS Inspector 2 IAM role connection
