Azure DevOps - Create record action
The Create record action creates a new record in Azure DevOps.
Input
Input fields are dynamically generated based on the object you select. The following input fields are common to all object types:
| Object | Select the object type of the record you plan to create. |
| Project | Select the project where you plan to create a new record. |
Output
Output fields are dynamically generated based on the object you select. Refer to the Azure DevOps documentation for a complete list of output fields.
