Azure DevOps - Get record action
The Get record action retrieves a record in Azure DevOps.
Input
Input fields are dynamically generated based on the object you select. The following input fields are common to all object types:
| Object | Select the object type of the record you plan to retrieve. |
Output
Output fields are dynamically generated based on the object you select. Refer to the Azure DevOps documentation for a complete list of output fields.
