# Azure Blob Storage - Container actions
The Azure Blob Storage connector allows you to create and search containers in your Azure Blob Storage Account.
# Create container action
This action creates a container in the connected Azure Blob Storage Account.
Input field | Description |
Container name | The name of the container. It can only contain lower-case characters with no spaces. |
Custom metadata | Custom metadata to attach to the container during creation. |
Access level | The access level for this container. By default, all containers created are private. You may make them public for various use cases. |
The output of this action will be a datatree that contains information about the request sent to Azure Blob Storage. To get information about the container, use the search container or get container properties action.
# Get container properties action
This action retrieves the properties of a container in the Azure Blob Storage Account.
Get container action
Container name | The name of the container. Choose from the available picklist or toggle to provide the container name manually. |
The properties of the container except custom metadata.
# Search containers action
This action search the containers in your Azure Blob Storage Account.
Search container action
Prefix | Prefix of container names to filter containers by. |
Page size | The max number of results returned from this action |
Next page marker | Optional. Used for pagination. |
The properties of the containers matching the search. The output also contains the "Next Marker" which can be used for pagination.
