# Google Analytics - New rows in batch trigger (batch)
The New rows in batch trigger activates when a new batch of rows is created in a Google Analytics report.
| Account | Select the account from the drop-down menu. |
| Property | Select the property from the drop-down menu. |
| Batch size | Specify the number of records to include in each batch. |
| Dimensions | Provide the dimensions source list and select the dimension fields from the drop-down menu. Dimensions are attributes of your data. |
| Metrics | Provide the metrics source list and select the metrics fields from the drop-down menu. Metrics are the quantitative measurements of a report. |
| Dimension filter | Specify dimension filters to return only specific dimension values in the report. Provide AND, OR or NOT expressions as needed. |
| Metric filter | Provide the filter clause of metrics to apply after aggregating the report's rows. Provide AND, OR, or NOT expressions as needed. |
| Metric aggregations | Select the aggregation of metrics from the drop-down menu. |
| Order bys | Provide the parameters to sort the result sets. This field specifies how rows are ordered in the response. |
| Currency code | Provide the currency code in ISO format, such as USD. |
| Cohort spec | Provide the cohort specs such as cohorts, cohorts range, and cohort report settings. |
| Dimension headers | A list of dimension columns. The number of dimension headers and ordering of dimension headers matches the dimensions present in rows. |
| Metric headers | A list of metric columns. The number of metric headers and ordering of dimension headers matches the metrics present in rows. |
| Rows | Rows of dimension value combinations and metric values in the report. |
| Totals | Displays the totaled values of metrics if requested. |
| Maximums | Displays the maximum values of metrics if requested. |
| Minimums | Displays the minimum values of metrics if requested. |
| Row count | The total number of rows available for the report. This may be greater than the number of rows returned if pagination is used. |
| Metadata | Contains information about the report. |
| Start date | Start date in 2021-01-01 format. |
| End date | End date in 2021-01-01 format. |
