Microsoft PowerPoint - Delete slide action
The Delete slide action removes one or more slides from a presentation in Microsoft PowerPoint. At least one slide must remain in the presentation.
THIS ACTION CAN'T BE UNDONE
You can't recover deleted slides. Confirm the slide numbers before you run this action.
Input
| File source | Select the service that stores the presentation. Options are OneDrive and SharePoint. |
| Presentation | Select the presentation, or enter the file ID. |
| Slide numbers | Enter the position of the slide or slides to delete. Accepts a single number or a list. |
Output
| Slides deleted | The number of slides the action deleted. |
| Remaining slides | The number of slides remaining in the presentation. |
| Skipped slide numbers (out of range) | The slide numbers the action excluded because they fall outside the presentation's range. |
| File ID | The unique ID of the presentation file. |
| File name | The name of the presentation file. |
| Web URL | The URL to view the presentation in a browser. |
| File ETag | The ETag of the presentation file. Use it to detect changes. |
| File last modified | The date and time of the last change to the presentation file. |
