Microsoft PowerPoint - Find and replace text action
The Find and replace text action finds and replaces text across every slide in a presentation in Microsoft PowerPoint. The action fails if it finds more than 1,000 matches. Narrow your search text or update slides individually with the Update text content action.
Input
| File source | Select the service that stores the presentation. Options are OneDrive and SharePoint. |
| Presentation | Select the presentation, or enter the file ID. |
| Find text | Enter the text to search for across all slides. |
| Replace with | Optional. Enter the replacement text. Deletes every instance of the found text if left blank. |
| Match case | Optional. Select to match the exact case of the Find text value. Options are Yes and No. Defaults to Yes if left blank. |
Output
| Total replacements made | The total number of replacements across the presentation. |
| Affected slides | The slides that contain replacements. |
| Slide number | The position of the affected slide. |
| Replacements on this slide | The number of replacements on the slide. |
| File ID | The unique ID of the presentation file. |
| File name | The name of the presentation file. |
| Web URL | The URL to view the presentation in a browser. |
| File ETag | The ETag of the presentation file. Use it to detect changes. |
| File last modified | The date and time of the last change to the presentation file. |
