Microsoft Word - Accept tracked change action ​
The Accept tracked change action accepts a specific tracked change by its ID. The action makes inserted text permanent and removes deleted text.
Input ​
Input fieldDescription
File sourceSelect where the document is stored. Options are OneDrive and SharePoint.
DocumentSelect the Word document from a folder-tree list scoped to the file source you selected.
Change IDEnter the ID of the tracked change to accept.
Output ​
The following are a representative set of output fields. Refer to the Microsoft Graph driveItem documentation for more information on available output fields.
Output fieldDescription
Action takenThe operation performed, such as accepted_insertion or accepted_deletion.
Document IDThe document's unique identifier.
ETagThe ID representing the document version after the tracked change was accepted.
Last modified dateThe date and time the document was last modified.
Last modified byThe application and user that last modified the document.
File nameThe document file name, including its extension.
Download URLA pre-authenticated URL you can use to download the document.
Web URLThe URL to view the document in the browser.
Parent referenceDetails about the document's parent folder, including drive type, drive ID, folder name, and path.
Size (bytes)The document size in bytes.
