Microsoft Word - Add comment action
The Add comment action adds a comment to a Word document, optionally anchored to a specific block. The action creates the comment under the authenticated user's identity.
Input
| File source | Select where the document is stored. Options are OneDrive and SharePoint. |
| Document | Select the Word document from a folder-tree list scoped to the file source you selected. |
| Comment text | Enter the text of the comment to add. |
| Anchor text | Optional. Anchor the comment to the paragraph that contains this text, instead of an element ID. The comment anchors to the block in Element ID if you leave this field blank, or to the first paragraph if you leave both blank. The Anchor text field is required when Occurrence is greater than 1. |
| Element ID | Optional. Anchor the comment to a specific content block by its element ID. The action scopes the match to this element when you also provide Anchor text. |
| Occurrence | Optional. If the anchor text appears more than once in the document, specify which occurrence to anchor the comment to. Defaults to 1. |
Output
The following are a representative set of output fields. Refer to the output datapills in the recipe editor to view additional output.
| Comment ID | The comment's unique identifier. |
| Author | The display name of the user the comment was created under. |
| Initials | The comment author's initials. |
| Content | The comment text. |
| Date | The date and time the comment was created. |
| Resolved | A boolean response (true or false) that indicates whether the comment is resolved. |
| Referenced text | The paragraph text the comment is anchored to. |
| Replies | The comment thread's replies. Returns one entry per reply. |
| Author (Replies) | The display name of the user the reply was created under. |
| Content (Replies) | The reply text. |
| Date (Replies) | The date and time the reply was created. |
