Microsoft Word - Get document info action ​
The Get document info action retrieves metadata and properties of a Word document, including file size, dates, and parent folder information, without returning its content.
Input ​
Input fieldDescription
File sourceSelect where the document is stored. Options are OneDrive and SharePoint.
DocumentSelect the Word document from a folder-tree list scoped to the file source you selected.
Output ​
The following are a representative set of output fields. Refer to the Microsoft Graph driveItem documentation for more information on available output fields.
Output fieldDescription
Download URLA pre-authenticated URL you can use to download the document.
Created byThe application and user that created the document.
Created dateThe date and time the document was created.
ETagThe ID representing the current version of the document metadata. Use this value for revision safety when updating the document.
Document IDThe document's unique identifier.
Last modified byThe application and user that last modified the document.
Last modified dateThe date and time the document was last modified.
File nameThe document file name, including its extension.
Parent referenceDetails about the document's parent folder, including drive type, drive ID, folder name, and path.
FileFile-level details, including the file extension and a hash value used to verify content integrity.
