Microsoft Word - Get document content action ​
The Get document content action returns structured content blocks, such as headings, paragraphs, lists, and tables, from a Word document. Filter results by section heading, block type, or search text, and use Max blocks and Page token to paginate through large documents.
Input ​
Input fieldDescription
File sourceSelect where the document is stored. Options are OneDrive and SharePoint.
DocumentSelect the Word document from a folder-tree list scoped to the file source you selected.
Section headingOptional. Filter content blocks to a specific section by its heading text.
Search textOptional. Filter content blocks to those containing the specified text.
Block type filterOptional. Filter content blocks by type, such as heading, paragraph, list, or table.
Match modeOptional. Determine how the action matches search text or filters against content blocks.
Max blocksOptional. Limit the number of content blocks returned in a single response. The response includes a Page token when more blocks remain.
Page tokenOptional. Provide the page token from a previous response to retrieve the next page of content blocks.
Output ​
The following are a representative set of output fields. Refer to the output datapills in the recipe editor for additional output.
Output fieldDescription
Content blocksThe document's structured content blocks. Returns one entry per block.
Element ID (Content blocks)The block's unique identifier. Pass this value to the Update document content action to target the block.
Block type (Content blocks)The block's type, such as paragraph or heading.
Text content (Content blocks)The block's text.
Total blocksThe total number of content blocks in the document.
Page tokenA token you can use to retrieve the next page of content blocks, if more exist.
Has moreA boolean response (true or false) that indicates whether additional content blocks are available beyond the current page.
