Microsoft Word - List tracked changes action (batch) ​
The List tracked changes (batch) action lists pending tracked changes in a Word document. Filter results by author and paginate through large result sets.
Input ​
Input fieldDescription
File sourceSelect where the document is stored. Options are OneDrive and SharePoint.
DocumentSelect the Word document from a folder-tree list scoped to the file source you selected.
Author filterOptional. Filter tracked changes by the display name of the author who made them.
Page sizeOptional. Set the number of tracked changes to return per page. Defaults to 20.
PageOptional. Specify the page number to retrieve. Defaults to 1.
Output ​
The following are a representative set of output fields. Refer to the output datapills in the recipe editor to view additional output.
Output fieldDescription
Tracked changesThe document's pending tracked changes. Returns one entry per change.
Change ID (Tracked changes)The change's unique identifier.
Change type (Tracked changes)The change's type, such as insertion or deletion.
Changed content (Tracked changes)The changed text.
Author (Tracked changes)The display name of the person who made the change.
Date (Tracked changes)The date and time the change was made.
Total countThe total number of tracked changes matching the filter.
PageThe current page number.
Next pageThe next page number, if more tracked changes exist.
Has moreA boolean response (true or false) that indicates whether additional tracked changes are available beyond the current page.
