Microsoft Word - Reject tracked change action ​
The Reject tracked change action rejects a specific tracked change by its ID. The action removes inserted text and restores deleted text.
Input ​
Input fieldDescription
File sourceSelect where the document is stored. Options are OneDrive and SharePoint.
DocumentSelect the Word document from a folder-tree list scoped to the file source you selected.
Change IDEnter the ID of the tracked change to reject.
Output ​
The following are a representative set of output fields. Refer to the Microsoft Graph driveItem documentation for additional output.
Output fieldDescription
Action takenThe operation performed, such as rejected_insertion or rejected_deletion.
Document IDThe document's unique identifier.
ETagThe ID representing the document version after the tracked change was rejected.
Last modified dateThe date and time the document was last modified.
Last modified byThe application and user that last modified the document.
File nameThe document file name, including its extension.
Download URLA pre-authenticated URL you can use to download the document.
Web URLThe URL to view the document in the browser.
Parent referenceDetails about the document's parent folder, including drive type, drive ID, folder name, and path.
Size (bytes)The document size in bytes.
