# Create record action
Use the Create record action to create a record in Orderful, such as a Transaction or Acknowledgment.
SUPPORTED TRANSACTION FORMATS
The Create record action supports creating transactions in both X12 and JSON formats. However, it supports creating an acknowledgment for JSON transactions only.
Acknowledgments for X12 transactions should be sent as 997 Functional Acknowledgments by the backend system that ingests the X12 file.
Orderful is configured to automatically acknowledge transactions by default, though this setting can be modified at the account and relationship level. You do not need to create an acknowledgment using the Create record action when automatic acknowledgments are enabled.
Refer to Orderful's documentation for more information about acknowledging a transaction (opens new window).
| Input fields | Description |
| Object | Use the Object drop-down to select the record you plan to create. Available options include Transaction and Acknowledgment. You must be the recipient of a Transaction to create an Acknowledgment. |
| Transaction type | Select a transaction type from the list of available EDI transaction types. This field is available when you select Transaction as the object to create.Refer to Orderful's documentation for more information about available transaction types (opens new window). |
| Stream | Specify the stream that the transaction belongs to. For example, test refers to your testing environment and live refers to your production environment.This field is available when you select Transaction as the object to create. |
| Sender | Select an ISA ID from your organization's EDI accounts. |
| Receiver | Enter the trading partner's ISA ID. This identifies the organization you're sending the EDI transaction to. This field is available when you select Transaction as the object to create. |
| Message | Provide the transaction document using the structure defined by the transaction type. Must be provided in JSON format. This field is available when you select Transaction as the object to create. |
| Transaction ID | Provide the ID of the transaction to acknowledge. This field is available when you select Acknowledgment as the object to create. |
| Status | Select an acknowledgment status, such as ACCEPTED or REJECTED.This field is available when you select Acknowledgment as the object to create.Refer to Orderful's documentation for more information about transaction statuses (opens new window). |
| Errors | Input a list datapill. This field is available when you select Acknowledgment as the object to create. |
| Path | Input the error path. This field is available when you select Acknowledgment as the object to create. |
| Code | Input the error code. This field is available when you select Acknowledgment as the object to create. |
| Message | Input the error message. This field is available when you select Acknowledgment as the object to create. |
The output for this action is dynamic and depends on the object created in Orderful.
# Transaction object output
| Transaction ID | Unique identifier of the transaction. |
# Acknowledgment object output
| Status | Indicates whether the acknowledgment was created successfully. |
Last updated: 9/30/2025, 9:31:24 PM
