Manual provisioning
You can manually configure user provisioning. This option doesn't enable you to sync users or groups from your IdP. You must define the user's access and user group membership when you manually add a user.
Prerequisites
You must have the following configurations before you can enable JIT provisioning:
- A configured SAML-SSO provider for Control plane
Enable manual provisioning
Complete the following steps to configure manual provisioning:
Expand the workspaces menu.
Click Control plane.
Sign in using your Control plane credentials or SSO.
Go to Control plane settings > Authentication.
Go to the Identity provider (IdP) for SAML SSO section and click the provisioning Setup now link for the IdP where you plan to enable manual provisioning.
Click Manual provisioning in the Provisioning modal.
Click Done.
