Configure Microsoft Dynamics 365 as a data pipeline source ​
Set up Microsoft Dynamics 365 as a data pipeline source to extract Sales, Customer Service, Field Service, and Marketing data from Microsoft Dataverse into your destination.
Use this guide to register a Microsoft Entra ID app, set up a connection, configure your pipeline, add objects, review sync behavior, and understand known limitations.
Microsoft Dynamics 365 features supported ​
The following features are supported when you use Microsoft Dynamics 365 as a pipeline source:
  • Cloud connectivity: Connect to your Dataverse environment over HTTPS. On-prem agents aren't required. Refer to Limitations for deployment restrictions.
  • Dynamic object discovery: Sync any table your connection can read, including custom tables. Refer to Supported objects for the objects Workato commonly syncs.
  • Full sync and incremental sync: Supports full sync and incremental sync modes. Incremental sync uses Dataverse's Change Tracking feature on the tables your administrator enables it for. Refer to Sync modes for more information.
  • Delete tracking: Detect deletions for supported objects and mark deleted records in your destination. Refer to Delete tracking for more information.
  • Schema drift detection and handling: Detect and apply schema changes automatically with Auto-sync new fields, or keep the schema fixed with Block new fields.
  • Field-level data protection: Hash or replicate sensitive fields as is before the data reaches your destination.
  • Configurable sync frequency: Schedule syncs on a time-based interval or with a cron expression. The minimum supported interval is 15 minutes.
Microsoft Dynamics 365 prerequisites ​
Complete the following requirements before you connect Microsoft Dynamics 365 as a data pipeline source:
  • A Microsoft Dynamics 365 environment (Sales, Customer Service, Field Service, or Marketing) hosted on Microsoft Dataverse. Refer to Limitations for deployment restrictions.
  • A Microsoft Entra ID app registration, and credentials for your chosen authentication method:
REQUIRED PERMISSIONS
Assign a Dataverse security role with Read privilege, at the organization level, for every table you plan to sync:
  • Client credentials: Assign the role to the Application User linked to your Entra app registration.
  • Authorization code grant: Assign the role to the Dataverse user that completes sign-in.
GRANT ACCESS TO NEW TABLES MANUALLY
Workato can discover a newly licensed app's tables or a new custom table and display it in the object list right away. Your connection can't read its data, though, until your Dataverse administrator manually grants Read access to that table for your connection's security role. Dataverse doesn't support a wildcard grant that automatically covers tables added later.
Supported connection types ​
Microsoft Dynamics 365 data pipelines support the following authentication methods:
  • Client credentials: Connect with a Microsoft Entra ID app registration and an Application User in your Dataverse environment. Workato recommends this method because pipelines run on an unattended schedule and don't depend on an interactive user session. Refer to Register the Workato app in the Azure Portal for setup steps.
  • Authorization code grant: Connect interactively with a Microsoft Entra ID app registration that has delegated permission to your Dataverse environment. Refer to Register the Workato app in the Azure Portal for setup steps.
Resource owner password credentials grant, supported by the Microsoft Dynamics 365 workflow connector, isn't available for data pipelines. Microsoft is deprecating password-based grants because they can't satisfy mandatory multi-factor authentication requirements.
Register the Workato app in the Azure Portal ​
Register a Microsoft Entra ID app registration in the Azure Portal before you connect Microsoft Dynamics 365 as a data pipeline source. The steps vary based on your chosen authentication method:
Return to Workato to finish setting up your connection.
Connect to Microsoft Dynamics 365 ​
Complete the following steps to connect to Microsoft Dynamics 365:
Configure the pipeline ​
Complete the following steps to configure Microsoft Dynamics 365 as your data pipeline source:
Click Start building.
Click the Extract new/updated records from source app trigger. This trigger defines how the pipeline retrieves data from Microsoft Dynamics 365.
Use the Your Connected Source Apps drop-down menu to select Microsoft Dynamics 365.
Choose the Microsoft Dynamics 365 connection you plan to use for this pipeline. Alternatively, click + New connection to create a new connection.
Click Add object to open the Add new objects panel. Workato dynamically discovers the tables your connection can read and displays each one as its display name and logical table name, for example, Account (account).
Add objectsAdd objects
Search or browse the list of available objects, select the objects you plan to sync, and click Add.
Select objectsSelect objects
Optional. Click the settings icon next to an object to configure how the object syncs. Use the Sync mode drop-down menu to select Full sync or Incremental. Workato defaults to full sync if it doesn't detect a Change Tracking cursor for the object. Refer to Sync modes for more information.
12
Optional. Expand an object to configure field-level data protection, then choose how to handle each field:
  • Replicate as is: Data values at the source replicate identically to the destination.
  • Hash: Hash sensitive data values in the field before they reach your destination.
Workato recommends you hash personally identifiable information (PII) and other sensitive fields. Refer to Sensitive data handling for a list of fields that commonly contain PII.
13
Click Add object again to add more objects. Repeat this step to include additional Microsoft Dynamics 365 objects in your pipeline.
14
Workato recommends Auto-sync new fields because Dataverse administrators can add custom fields to any table at any time.
15
Optional. Enter a value in the Concurrency limit field to cap the number of concurrent operations. Leave the field blank to use the default quota set by Workato. The maximum value is 100.
16
Choose either a standard time-based schedule or define a custom cron expression in the Frequency field. This determines how often the pipeline syncs data from Dynamics 365 to the destination.
Supported Microsoft Dynamics 365 objects ​
Microsoft Dynamics 365 data pipelines sync data from Microsoft Dataverse, the shared data platform behind Sales, Customer Service, Field Service, and Marketing (Customer Insights – Journeys). Workato dynamically discovers every table your connection can read, including custom tables, so you're not limited to the objects listed below. The following tables list commonly synced objects, grouped by app area. Each object syncs as a separate table in your destination.
TABLE CAPABILITIES VARY BY ENVIRONMENT
The available sync mode and delete tracking are determined for each table in your Dataverse environment. Incremental sync and delete tracking are available only when Change Tracking is enabled for that table. Permissions, licensing, and installed applications can also affect whether a listed table is available.
Shared across apps ​
ObjectSync modeDelete trackingNotes
AccountFull sync, incrementalYes (soft)N/A
ContactFull sync, incrementalYes (soft)N/A
TaskFull sync, incrementalYes (soft)Activity table
EmailFull sync, incrementalYes (soft)Activity table
Phone CallFull sync, incrementalYes (soft)Activity table
AppointmentFull sync, incrementalYes (soft)Activity table
NoteFull sync, incrementalYes (soft)Attachments aren't synced.
UserFull sync, incrementalYes (soft)Typically deactivated rather than deleted
TeamFull sync, incrementalYes (soft)N/A
Business UnitFull sync, incrementalYes (soft)Organization hierarchy
Sales ​
LeadFull sync, incrementalYes (soft)N/A
OpportunityFull sync, incrementalYes (soft)N/A
Opportunity ProductFull sync, incrementalYes (soft)Child of Opportunity
QuoteFull sync, incrementalYes (soft)N/A
Quote DetailFull sync, incrementalYes (soft)Child of Quote
OrderFull sync, incrementalYes (soft)N/A
Order ProductFull sync, incrementalYes (soft)Child of Order
InvoiceFull sync, incrementalYes (soft)N/A
Invoice DetailFull sync, incrementalYes (soft)Child of Invoice
ProductFull sync, incrementalYes (soft)N/A
Price ListFull sync, incrementalYes (soft)N/A
Price List ItemFull sync, incrementalYes (soft)Volume can exceed Product × Price List count
CompetitorFull sync, incrementalYes (soft)N/A
GoalFull sync, incrementalYes (soft)Implements Dynamics 365 Sales Plans
Goal MetricFull sync, incrementalYes (soft)N/A
Goal Rollup QueryFull syncYes (destination-inferred)Child of Goal
Customer service ​
CaseFull sync, incrementalYes (soft)description frequently contains customer-disclosed PII
QueueFull sync, incrementalYes (soft)N/A
Queue ItemFull sync, incrementalYes (soft)N/A
EntitlementFull sync, incrementalYes (soft)N/A
SLAFull sync, incrementalYes (soft)N/A
SLA ItemFull syncYes (destination-inferred)N/A
Knowledge ArticleFull sync, incrementalYes (soft)N/A
Case ResolutionFull sync, incrementalYes (soft)Created when a case is resolved
Social ActivityFull sync, incrementalYes (soft)Only present if social channels are configured
Field service ​
Bookable Resource, Bookable Resource Booking, and Customer Asset ship with the base Universal Resource Scheduling capability. The remaining objects in this category require the Field Service app.
Bookable ResourceFull sync, incrementalYes (soft)N/A
Bookable Resource BookingFull syncYes (destination-inferred)N/A
Customer AssetFull sync, incrementalYes (soft)N/A
Work OrderFull sync, incrementalYes (soft)Requires the Field Service app
Work Order IncidentFull sync, incrementalYes (soft)Requires the Field Service app
Work Order ServiceFull sync, incrementalYes (soft)Requires the Field Service app
Work Order Service TaskFull sync, incrementalYes (soft)Requires the Field Service app
Work Order ProductFull sync, incrementalYes (soft)Requires the Field Service app
Resource RequirementFull sync, incrementalYes (soft)Requires the Field Service app
Work Order TypeFull syncNoReference data. Requires the Field Service app
Incident TypeFull syncNoReference data. Requires the Field Service app
AgreementFull sync, incrementalYes (soft)Requires the Field Service app
Marketing ​
Subscription List, Consent, Purpose, and Topic ship with base Dataverse. The remaining objects in this category require Customer Insights – Journeys (Marketing).
Subscription ListFull sync, incrementalYes (soft)Labeled "Marketing List" in the Dynamics 365 UI
ConsentFull sync, incrementalYes (soft)Contact Point Consent: GDPR/CAN-SPAM opt-in and opt-out state
PurposeFull sync, incrementalYes (soft)N/A
TopicFull sync, incrementalYes (soft)Child of Purpose
SegmentFull sync, incrementalYes (soft)Requires Customer Insights – Journeys
Customer JourneyFull sync, incrementalYes (soft)Requires Customer Insights – Journeys
Marketing EmailFull sync, incrementalYes (soft)Requires Customer Insights – Journeys
Marketing FormFull sync, incrementalYes (soft)Requires Customer Insights – Journeys
EventFull sync, incrementalYes (soft)Requires Customer Insights – Journeys
Event RegistrationFull sync, incrementalYes (soft)Requires Customer Insights – Journeys
Marketing also writes to the shared Contact and Lead tables in the Shared across apps category rather than a separate marketing-only person record.
Custom tables and fields ​
Dataverse customers can create entirely new custom tables, not just custom fields on standard tables. Workato discovers custom tables the same way it discovers standard tables, and syncs them identically. Custom tables and fields use a publisher-defined prefix, such as new_ or cr123_. Workato preserves this prefix in the field and table names it syncs to your destination.
Sync modes ​
Microsoft Dynamics 365 data pipelines support full sync and incremental sync. The sync mode is configured per object when you add it to your pipeline.
Full sync ​
A full sync reads all available records for the selected object from Dataverse on every run. Objects without Change Tracking enabled use full sync, because Dataverse doesn't provide a way to fetch only changed records for them.
Objects with a primary key merge into the existing destination table, so records deleted in Dataverse stay in the table. Objects without a primary key overwrite the destination table on every run.
Incremental sync ​
An incremental sync extracts only records created, updated, or deleted since the last successful run. Microsoft Dynamics 365 data pipelines use Dataverse's Change Tracking feature for incremental sync. The first sync requests a delta link for the object, and later syncs use that delta link to fetch only the changes since the previous run.
Change Tracking is a per-table setting your Dataverse administrator enables in the Power Apps maker portal, and it's permanent. Your administrator can't turn it off again. Workato uses full sync instead for any object without Change Tracking enabled, so expect some tables in the same environment to have it enabled and others not. This is normal.
Refer to the Supported objects tables for commonly synced objects, and to Microsoft's Change Tracking documentation to enable it for eligible tables.
FIRST SYNC READS EVERY RECORD ON INCREMENTAL OBJECTS
Dataverse requires Workato to read every available record on an incremental object's first sync, before it can establish the delta link used for later syncs. Your historical start date doesn't reduce this cost, though Workato still excludes older records from the destination. Large objects can take multiple sync cycles to complete their first sync.
Delete tracking ​
Delete tracking is per-object, and depends on the object's sync mode:
  • Objects with incremental sync: Dataverse's Change Tracking feed includes a "removed" entry with the deleted record's ID whenever a tracked record is deleted. Workato marks these records as deleted in the destination and doesn't remove them.
  • Objects with full sync: Dataverse doesn't expose a native delete signal for these objects. Workato compares each full sync against the previous run and marks records that no longer appear in Dynamics 365 as deleted in the destination, because it reads the complete object every time.
Refer to Synthetic columns for the destination column this sets, and to the Supported objects tables for which objects use each sync mode.
Schema and data type handling ​
The following considerations apply to schema and data types when you sync data from Microsoft Dynamics 365.
Custom fields ​
Custom fields appear identically to standard fields in the schema Workato discovers for each object. Select Auto-sync new fields in Configure the pipeline so new custom fields sync automatically. Dataverse administrators can add custom fields to any table at any time.
Picklist, State, and Status fields ​
Picklist, State, and Status fields sync as their underlying integer option value, not the display label shown in the Dynamics 365 UI. Look up the label for a specific value in your Dataverse environment's option set definitions if you need the corresponding text.
Lookup fields ​
Dataverse doesn't nest related records inside an object's data. A lookup field, including Customer and Owner fields, syncs as the GUID of the related record rather than an expanded object. Sync the parent object as its own table to look up the related record's details.
Money fields ​
Money fields sync as a single decimal value. The related transaction currency syncs separately, as a lookup field on the same record, rather than paired with each Money field.
Timestamps ​
Dataverse returns date and time fields in UTC through the Web API, regardless of the timezone shown in the Dynamics 365 UI. Workato preserves these values as returned.
Synthetic columns ​
Workato adds the following synthetic column to destination tables for objects that use incremental sync:
ColumnTypePurpose
_workato_is_deletedBooleanSet to true for records Dataverse's Change Tracking feed reports as removed. Refer to Delete tracking for more information.
Sensitive data handling ​
Microsoft Dynamics 365 objects can contain significant personally identifiable information (PII), and Customer Service and Field Service objects can contain health or safety-adjacent information. The following objects commonly contain sensitive fields:
ObjectSensitive fields
Contactfullname, emailaddress1, emailaddress2, emailaddress3, telephone1, telephone2, mobilephone, address1_*, address2_*, birthdate
Accountaddress1_*, telephone1, and other billing contact details
Leadfullname, emailaddress1, telephone1, companyname
Casedescription, which frequently contains customer-disclosed PII
Email, Phone Call, AppointmentBody and description fields may contain any PII shared in correspondence
Work Ordermsdyn_instructions, service address, and linked Contact or Account PII
Customer AssetInstalled-equipment address and site-access details
Consent, Subscription ListConsent or subscription status tied to an identifiable Contact or Lead
UserInternal employee name, email, and phone
Microsoft Dynamics 365 limitations ​
The following limitations apply when you use Microsoft Dynamics 365 as a data pipeline source:
Cloud-hosted Dataverse only ​
Microsoft Dynamics 365 data pipelines connect to cloud-hosted Dataverse environments only. On-premises Dynamics 365 deployments that use AD FS for authentication, supported by the Microsoft Dynamics 365 workflow connector, aren't supported as a data pipeline source.
Marketing engagement data is not synced ​
Segment and Customer Journey definitions sync as ordinary tables, but most engagement data isn't available through the Dataverse Web API, including who's in a segment, email opens, clicks, page views, form fills, and journey-step events. This applies whether your environment uses legacy outbound marketing or real-time marketing (Customer Insights – Journeys). The pipeline can still sync segment and journey definitions, consent records, email and form templates, and Marketing's writes into the shared Contact and Lead tables.
Calculated, formula, and rollup fields can go stale between syncs ​
Values in these fields can lag behind their true value until the object's next full sync, on objects configured for incremental sync. Updates to the data these fields are based on don't reliably trigger a Change Tracking event. Configure a periodic full sync for objects where these fields matter.
Minimum sync frequency ​
