Configure GitHub as a data pipeline source ​
Set up GitHub as a data pipeline source to extract repositories, issues, pull requests, commits, and related development records from the GitHub REST and GraphQL APIs and sync them to your destination.
Use this guide to review the features and prerequisites, connect GitHub as a data pipeline source, configure the pipeline, and understand the supported objects, sync modes, schema handling, sensitive data handling, and limitations.
GitHub features supported ​
The following features are supported when you use GitHub as a pipeline source:
  • Cloud and self-hosted connectivity: Connect to GitHub.com and GitHub Enterprise Cloud over https. Route the connection through an on-prem agent to connect to a self-hosted GitHub Enterprise Server instance.
  • Organization-scoped syncing: Select one or more GitHub organizations when you configure the pipeline. Workato syncs every repository in those organizations that your connection can access.
  • Object-level selection: Select the objects you plan to sync as separate tables in your destination. Refer to Supported objects for the full list.
  • Full sync and incremental sync: The Issue, IssueComment, Commit, and ReviewComment objects support incremental sync using GitHub's since parameter. Every other object syncs in full on each run. Refer to Sync modes for more information.
  • Delete tracking: Workato compares each full sync against the previous run and marks records that no longer exist in GitHub as deleted in your destination.
  • Schema drift detection and handling: Detect and apply schema changes automatically with Auto-sync new fields, or keep the schema fixed with Block new fields.
  • Field-level data protection: Hash or replicate sensitive fields as is before the data reaches your destination.
  • Configurable sync frequency: Schedule syncs on a time-based interval or with a cron expression. The minimum supported interval is 15 minutes.
GitHub prerequisites ​
Connecting GitHub as a data pipeline source requires:
  • A GitHub.com, GitHub Enterprise Cloud, or GitHub Enterprise Server account with access to the organizations and repositories you plan to sync
  • One or more GitHub organization logins to scope the pipeline to
  • An on-premises agent, if you connect to a self-hosted GitHub Enterprise Server instance
  • Credentials for your chosen authentication method:
    • OAuth App: A GitHub account with permission to authorize Workato's registered OAuth App
    • Personal access token: A classic or fine-grained personal access token generated from your GitHub account
Required permissions ​
Grant only the read-level permissions needed to sync your selected objects:
GitHub permission categoryClassic OAuth App / personal access token scopeFine-grained personal access token permissionWorkato objects
Repository contents and metadatarepoContents: Read-only, Metadata: Read-onlyRepository, Branch, BranchCommitRelation, Tag, Commit, CommitComment, CommitFile, RepositoryTopic, RepositoryLanguage
IssuesrepoIssues: Read-onlyIssue, IssueComment, IssueLabel, IssueAssignee, IssueEvent, Label, Milestone
Pull requestsrepoPull requests: Read-onlyPullRequest, PullRequestCommit, PullRequestReview, ReviewComment, RequestedReviewerHistory
ActionsrepoActions: Read-onlyWorkflow, WorkflowRun, WorkflowRunJob, CommitStatus
Actions check runsrepoActions: Read-only, plus Checks: Read-onlyCommitCheckRun
DeploymentsrepoDeployments: Read-onlyDeployment, DeploymentStatus
Organization members and teamsread:orgMembers: Read-only (organization level)Team, TeamMember, RepositoryTeam, User, Collaborator
Account identityread:userNot applicableRequired for the connection check only
Dependabot alertssecurity_eventsDependabot alerts: Read-onlySecurityAlert
DON'T GRANT THE WORKFLOW SCOPE
The workflow scope authorizes writing to Actions workflow files. A data pipeline connection only reads data and doesn't need this scope.
Supported connection types ​
GitHub data pipelines support two authentication methods:
  • OAuth App: Authorize Workato's registered GitHub OAuth App through the standard browser redirect flow. OAuth tokens are long-lived and don't expire unless you revoke the authorization or the OAuth App is deleted.
  • Personal access token: Provide a classic or fine-grained personal access token generated from your GitHub account. Workato recommends this method for server-to-server setups where an interactive OAuth flow isn't practical.
Connect to GitHub ​
Complete the following steps to connect GitHub as a data pipeline source:
Connect to GitHub
OAuth authentication ​
Complete the following steps to connect your GitHub to Workato using OAuth authentication:
Sign in to your Workato account and go to the project where you plan to add your GitHub connection.
Click Create > Connection (or press C twice), then select GitHub as your connection.
Provide a Connection name that identifies which GitHub instance Workato is connected to.
Use the Authentication type drop-down menu and select OAuth App.
Optional. Click Advanced configuration to display the Host name field.
Optional. Enter a Host name. This is applicable when using Github Enterprise Server. Enter your Github subdomain. For example, if your host URL is https://github.example-organisation.com, the subdomain is github.example-organisation.com.
Click Connect. Workato redirects you to GitHub. The OAuth App requests authorization to access your GitHub account.
Personal access token authentication ​
Retrieve your personal access token from GitHub to connect your GitHub account to Workato using a personal access token:
Retrieve personal access token ​
Go to Github account > Settings > Developer settings > Personal access tokens > Generate new token.
Click Generate new token.
Copy the token. Enter this token in Workato to authenticate the connection.
Complete setup in Workato ​
Complete the following steps to set up your GitHub connection using a personal access token:
Use the Authentication type drop-down menu and select Personal Access Token.
Optional. Enter a Host name. This is applicable when using Github Enterprise Server. Enter your Github subdomain. For example, if your host URL is https://github.example-organisation.com, your subdomain is github.example-organisation.com.
Enter your Personal Access Token.
Optional. Enter a Custom OAuth profile. This ensures all requests to the app use the specified profile.
Configure the pipeline ​
Complete the following steps to configure GitHub as your data pipeline source:
Click Start building.
Click the Extract new/updated records from source app trigger. This trigger defines how the pipeline retrieves data from GitHub.
Use the Your Connected Source Apps drop-down menu to select GitHub.
Choose the GitHub connection you plan to use for this pipeline. Alternatively, click + New connection to create a new connection.
Enter one or more GitHub organization logins, separated by commas, in the Organizations field. Workato syncs only the repositories in these organizations that your connection can access, and doesn't expand the scope beyond the organizations you enter here.
Add objectsAdd objects
Search or browse the list of available GitHub objects, select the objects to sync, and click Add.
HIGH-VOLUME OBJECTS
The CommitFile and BranchCommitRelation objects re-read commit-level data in full on every sync and can generate a very large number of rows for repositories with long commit histories. Refer to High-volume objects require careful sync planning before you add either object.
12
  • Replicate as is: Data values at the source replicate identically to the destination.
  • Hash: Hash sensitive data values in the field before syncing to your destination.
13
Click Add object again to add more objects. Repeat this step to include additional GitHub objects in your pipeline.
14
15
Optional. Enter a value in the Concurrency limit field to cap the number of concurrent operations. Leave the field blank to use the default quota set by Workato. The maximum value is 100.
16
Choose either a standard time-based schedule or define a custom cron expression in the Frequency field. This determines how often the pipeline syncs data from GitHub to the destination.
Supported GitHub objects ​
GitHub data pipelines sync data from the GitHub REST API, and from the GraphQL API for pull request reviews and releases. The following tables list the supported objects, grouped by category. Each object syncs as a separate table in your destination:
Organizations, repositories, and access ​
ObjectSync modesDelete tracking
RepositoryFull syncYes
TeamFull syncYes
TeamMemberSyncs with the parent Team objectYes
RepositoryTeamFull syncYes
UserFull syncYes
CollaboratorFull syncYes
Issues and pull requests ​
GitHub returns issues and pull requests from the same endpoint. Workato distinguishes them by checking for a pull_request field on each record, so the Issue object excludes any row shaped like a pull request:
IssueFull sync, incrementalNo
IssueCommentFull sync, incrementalNo
IssueLabelSyncs with the parent Issue objectNo
IssueAssigneeSyncs with the parent Issue objectNo
IssueEventFull syncYes
LabelFull syncYes
MilestoneFull syncYes
PullRequestFull syncYes
PullRequestCommitSyncs with the parent PullRequest objectYes
PullRequestReviewSyncs with the parent PullRequest objectYes
ReviewCommentFull sync, incrementalNo
RequestedReviewerHistorySyncs with the parent PullRequest objectYes
Commits and repository content ​
CommitFull sync, incrementalNo
CommitCommentFull syncYes
CommitStatusSyncs with the parent Commit objectNo
CommitCheckRunSyncs with the parent Commit objectNo
BranchFull syncYes
BranchCommitRelationSyncs with the parent Branch objectYes
TagFull syncYes
RepositoryTopicSyncs with the parent Repository objectYes
RepositoryLanguageSyncs with the parent Repository objectYes
CommitFileSyncs with the parent Commit objectNo
CommitFile and BranchCommitRelation are opt-in, high-volume objects. Refer to High-volume objects require careful sync planning before you add either object.
CI/CD and releases ​
WorkflowFull syncYes
WorkflowRunFull syncYes
WorkflowRunJobSyncs with the parent WorkflowRun objectYes
DeploymentFull syncYes
DeploymentStatusSyncs with the parent Deployment objectYes
ReleaseSyncs with the parent Repository objectYes
Engagement and security ​
StargazerFull syncYes
SecurityAlertFull syncYes
SecurityAlert requires Dependabot to be enabled on the repository and the appropriate permission granted to your connection. Refer to Dependabot alerts require repository and permission setup for more information.
Sync modes ​
GitHub data pipelines support full sync and incremental sync. Refer to Supported objects to see the sync mode for each object.
Full sync ​
A full sync reads all available records from GitHub for the selected object on every run. Objects with a primary key merge into the existing destination table, so records deleted in GitHub stay in the table. Objects without a primary key overwrite the destination table on every run.
Incremental sync ​
An incremental sync extracts only records GitHub reports as created or updated since the last successful run, using GitHub's since parameter as the cursor. Only Issue, IssueComment, Commit, and ReviewComment support incremental sync. Every other object, including objects that sync alongside a parent object such as IssueLabel or WorkflowRunJob, syncs in full.
Delete tracking ​
Workato compares each full sync against the previous run and marks records that no longer exist in GitHub as deleted in your destination. This applies to every full-sync object.
GitHub's since parameter doesn't report deletions, so Issue, IssueComment, Commit, and ReviewComment don't track deletes during incremental sync. A record deleted in GitHub stays in your destination for these objects. Refer to Incremental objects do not track deletions for more information.
Schema and data type handling ​
The following considerations apply to schema and data types when you sync data from GitHub:
Nested fields ​
GitHub responses include nested objects and arrays, such as the base and head branch references on a pull request or the raw commit metadata on a commit. Workato stores these as JSON columns rather than flattening them into individual columns.
Workato syncs JSON fields to the destination's native JSON type, such as VARIANT in Snowflake. Workato serializes JSON fields as strings if the destination doesn't support a native JSON type.
Custom properties are not synced ​
GitHub Enterprise Cloud and GitHub Enterprise Server support repository-level custom properties. Workato doesn't sync custom properties in this release. Only the standard fields listed for each object are available.
Sensitive data handling ​
GitHub objects can contain personally identifiable information (PII). The following objects commonly contain sensitive fields:
ObjectSensitive fields
Commitcommit.author.name, commit.author.email, commit.committer.name, commit.committer.email
Issueuser.login, body, assignees
IssueCommentuser.login, body
PullRequestuser.login, body, head.label, merge_commit_sha
ReviewCommentuser.login, body
Userlogin, name, email, avatar_url
Collaboratorlogin, email
The body field on Issue, IssueComment, PullRequest, and ReviewComment is free text. Contributors can paste account information, credentials, or other customer data into issue descriptions, pull request descriptions, and comments, so these fields carry the highest risk.
GitHub limitations ​
The following limitations apply when you use GitHub as a data pipeline source:
Incremental objects do not track deletions ​
Issue, IssueComment, Commit, and ReviewComment sync incrementally using GitHub's since parameter, which doesn't report deletions. A record deleted in GitHub stays in your destination for these objects. Refer to Delete tracking for more information.
You can't filter to specific repositories ​
The pipeline syncs every repository within your selected organizations that your connection can access. You can't include or exclude individual repositories. Personal repositories that don't belong to an organization aren't synced.
High-volume objects require careful sync planning ​
The CommitFile and BranchCommitRelation objects can generate a high volume of records. CommitFile requires one API call per commit to retrieve file-level diff data, with no bulk endpoint available.
Dependabot alerts require repository and permission setup ​
The SecurityAlert object syncs Dependabot security alerts. It returns no rows for repositories where Dependabot is disabled, and the sync fails for that object if your connection lacks the required permission. Refer to Required permissions for the scope you need to grant.
GitHub Enterprise Server version differences ​
GitHub Enterprise Server can run several versions behind GitHub.com. Some objects and fields available on GitHub.com may not be available on your GitHub Enterprise Server instance until you upgrade.
Minimum sync frequency ​
