Configure Amazon S3 as your data pipeline source ​
Set up Amazon S3 as a data pipeline source to extract and sync records into your destination. This guide includes connection setup, pipeline configuration, and key behavior for working with .csv and .parquet files in S3 buckets.
Features supported ​
The following features are supported when using Amazon S3 as a data pipeline source:
  • Extract and sync data from .csv and .parquet files stored in S3
  • Support for full and incremental sync via file detection
  • Field-level selection for object extraction
  • Field-level data masking
Prerequisites ​
  • An AWS account with an S3 bucket that stores .csv or .parquet files
  • IAM role authentication configured for Workato
  • Required S3 permissions for the pipeline to list and read files
  • Folder paths and file patterns for the files to sync
How to connect ​
Complete the following steps to connect to Amazon S3 as a data pipeline source. This connection allows the pipeline to read and extract .csv and .parquet files from S3.
ACCESS KEY AUTHENTICATION DEPRECATED
Workato recommends using IAM role authentication. Access key authentication remains functional for existing connections, but Workato doesn't recommend it for new environments.
Connect to Amazon S3
Search for Amazon S3 and select it as your app.
Amazon S3 connection setupAmazon S3 connection setup
Select Cloud in the Connection type field, unless you need to connect through an on-prem group.
Select IAM role as the Authorization type.
Enter the ARN of the role configured in your AWS account in the IAM role ARN field. The IAM role must include permissions that grant Workato access to the buckets and folders required for pipeline extraction.
Optional. Enter a value in the Restrict to bucket field to limit the connection to a specific bucket. Use this setting when the IAM role has limited list permissions.
Enter the Region for the S3 bucket. For example, if your S3 console URL is https://us-west-1.console.aws.amazon.com/, enter us-west-1.
Optional. Enter a value in the Download threads field to increase file download concurrency. The default value is 1, and the maximum is 20.
Select Connect to verify and store the connection.
Configure the pipeline ​
Complete the following steps to configure Amazon S3 as your data pipeline source:
Click Start building.
Use the Your Connected Source Apps drop-down menu to select Amazon S3.
Choose the Amazon S3 connection you plan to use for this pipeline. Alternatively, click + New connection to create a new connection.
Choose an Amazon S3 connectionChoose an Amazon S3 connection
Select the S3 bucket you plan to monitor in the Bucket field.
Select S3 bucketSelect S3 bucket
Click Add object to configure files you plan the pipeline to monitor and sync.
Workato doesn't browse your S3 bucket. You must manually enter the folder path and file pattern. Ensure the path and filenames match your S3 structure.
Enter the folder within the bucket to monitor in the Source Folder path field. The pipeline monitors this folder and fetches files that match your filename pattern.
Configure file settingsConfigure file settings
Use the File type drop-down menu to select the file format to extract. Workato supports the following file types:
  • CSV: Extract data from .csv files. Requires additional file type settings configuration.
  • Parquet: Extract data from .parquet files. Schema and data types are inferred directly from the file.
12
Define which files to fetch using a pattern in the Filename pattern field. Use wildcards, such as orders_*, to include multiple files. The file extension is appended automatically based on the File type you select.
13
Click Fetch matching files to preview files matching the defined pattern.
14
Select a Reference file to define the schema for the destination table.
15
Configure file type-specific settings:
16
Click Fetch schema to load and preview columns from the reference file.
17
Review the schema to ensure it matches your expected table structure. The schema preview includes the columns from your source file along with the following system-generated columns:
  • _file: The name of the source file each row originated from.
  • _line: The line or row number of each record within the source file.
Review schemaReview schema
18
Configure how rows are merged in the destination table in the Choose a merge strategy field. Workato supports the following merge strategies:
  • Upsert: Inserts new rows and updates existing rows. The Merge method field appears when you choose Upsert. You can select one or more columns to use as the primary key for the destination table. The pipeline uses the system-generated _file and _line columns as a composite primary key if you leave Merge method blank.
  • Append only: Inserts all rows without attempting to match or update existing records. The pipeline doesn't match on a key and doesn't update existing rows when you choose Append only.
19
Click Review object to confirm your setup. This screen displays your file settings, file type-specific options, and merge details.
Review objectReview object
20
Enter an Object name. This name defines the destination table name.
21
Click Finish to save the object configuration.
22
Expand objectExpand object
Expand any object to view its fields. Keep all fields selected to extract all available data, or deselect specific fields to exclude them from data extraction and schema replication.
23
Optional. Configure field-level data protection. After you expand an object, choose how to handle each field:
  • Replicate as is (default): Data values at the source are replicated identically to the destination.
  • Hash: Hash sensitive data values in the column before syncing to your destination.
Configure field-level data protectionConfigure field-level data protection
24
Click Add object again to add more objects using the same flow. You can repeat this step to include multiple Amazon S3 objects in your pipeline.
25
26
Choose either a standard time-based schedule or define a custom cron expression in the Frequency field. This determines how often the pipeline syncs data from Amazon S3 to the destination.
