Configure SAP Table Reader (SAP Data Agent) ​
The SAP Table Reader enables you to extract SAP table data into data pipelines using the SAP Data Agent.
This integration uses an asynchronous, package-based extraction method to securely and efficiently handle large datasets.
Overview ​
SAP Table Reader uses the SAP Data Agent to transfer data from SAP to Workato.
The following occurs when a pipeline runs:
  1. Workato sends an extraction request to SAP.
  2. SAP Data Agent collects data and stores it in temporary packages.
  3. Workato retrieves the packages sequentially.
  4. SAP Data Agent deletes temporary data after completion.
You can monitor logs in SAP using transaction code SLG1.
SAP Data Agent processes extraction requests asynchronously. It stages data temporarily in SAP and transfers it to Workato in controlled packages to handle large datasets efficiently.
Supported source types ​
SAP Table Reader supports the following source types:
  • Transparent tables
  • Pool tables
  • Cluster tables
  • Traditional database views
  • CDS views without parameters
SAP Table Reader doesn't support the following:
  • Consumption views
  • AMDP (ABAP Managed Database Procedures)
  • CDS views with parameters
Set up SAP Data Agent ​
You must install and configure the SAP Data Agent on the SAP application server before creating a data pipeline.
SAP Data Agent installs as an ABAP transport in the SAP system. It exposes OData services under the /WKTO/ namespace and enables secure, package-based data extraction.
Supported SAP systems ​
The following SAP systems support SAP Data Agent – Table Reader:
SAP systemDatabaseNetWeaver versionABAP version
SAP ECCAny7.4 EHP7 and above7.4 and above
SAP S/4HANASAP HANA1610 and above7.5 and above
SAP BWAny7.4 EHP7 and above7.4 and above
SAP BW/4HANASAP HANA2.0 SPS07 and above7.5 and above
Create an SAP user account ​
You must create a dedicated SAP Communication user (type C) with the required authorization. Data pipelines support only basic authentication.
Provide the SAP username and password of the SAP Communication user.
Assign the required SAP roles and authorization objects before testing connectivity.
Install SAP Data Agent ​
You must install SAP Data Agent by importing the ABAP transport request into the SAP system.
TRANSPORT REQUEST REQUIRED
Contact your Workato Account Executive or Customer Success Manager to obtain the ABAP transport request package.
The installation activates required OData services, assigns runtime components, and enables extraction under the /WKTO/ namespace.
Complete the following steps to install the SAP Data Agent:
Import the SAP transport request provided by Workato.
Assign the required SAP authorizations and roles to the user.
Activate SICF (SAP Internet Communication Framework transaction) services under the /WKTO/ namespace.
Maintain the local alias for services in transaction /IWFND/MAINT_SERVICE.
Maintain required parameters in transaction /WKTO/CONFIG:
  • Maintain CSV_SEP to set the CSV separator. Use | (pipe).
  • Maintain MSTR_CLEANUP to set the number of days before pipeline cleanup in the internal master table. Use 7 as the recommended value.
  • Maintain FILEPATH to set the AL11 path for storing export files. For example, D:\WORKATO\EXPORT\.
Tune package size for large tables using transaction /WKTO/PACK. Very large tables require package size tuning. Refer to the Troubleshooting guide for additional guidance.
Configure SAP role for Table Reader ​
Assign the required role and authorizations to the SAP user used for SAP Data Agent.
This role grants access to required OData services, background job processing, and table-level permissions for data extraction.
Go to transaction code PFCG.
Open role /WKTO/TABLE_READER, or create a custom role that includes the required authorization objects.
Go to the Authorizations tab and select Change Authorization Data.
Ensure the role includes the following authorization objects and field values:
Summary of authorization included in the role
S_SERVICE
Authorizes access to SAP Data Agent OData services under the /WKTO/ namespace.
S_BTCH_ADM
Controls background job administration permissions.
S_BTCH_JOB
Authorizes release and execution of background jobs used during extraction.
S_TABU_DIS
Controls access to table authorization groups.
S_TABU_NAM
Controls access to specific table names.
Authorization Field Values for S_SERVICE Object
Required for SAP Data Agent OData Services
Program, transaction or Function
SRV_NAME
Values:
  • 0AE2A6D56834889146773B86C3B4A4 (/WKTO/DA_CM_SRV)
  • 9CB49C41E6503E8A3BF6A9CE025B88 (/WKTO/DA_LOG_SRV_0001)
  • B80B26B216EE837EDD71ECBCC2A106 (/WKTO/DA_TBL_SRV_0001)
  • BF83C9264549804E40E46A704B73A0 (/WKTO/DA_CM_SRV_0001)
  • C45237A6760D58CFA80609CAE052B9 (/WKTO/DA_TBL_SRV)
  • ECE235D66D4238FC5D4C2F97A16A4F (/WKTO/DA_LOG_SRV)
Type of check Flag (SRV_TYPE)
HT
Authorization Field Values for S_BTCH_ADM Object
Required for Background Job Administration
Background Administrator
N
Authorization Field Values for S_BTCH_JOB Object
Required for Background Job Execution
Job Operations
RELE
Summary of jobs for a group
Authorization Field Values for S_TABU_DIS Object
Required for Table Access by Authorization Group
Activity
02, 03
Table Authorization Group
VA
Authorization Field Values for S_TABU_NAM Object
Required for Table-Level Access
Activity
03
Table Name
Generate the authorization profile and save the role.
Assign the role to the SAP user used for SAP Data Agent.
Establish OData connectivity between Workato and SAP ​
You must configure connectivity between Workato and the SAP system before creating a data pipeline.
SAP Data Agent exposes OData services that Workato uses for authentication, extraction, and cleanup operations.
Connect to SAP on-premise systems ​
Deploy a Workato on-prem agent (OPA) if your SAP system doesn't expose OData services to the public internet.
The on-prem agent establishes a secure outbound connection from your network to Workato and enables access to internal SAP OData services.
Complete the following steps to connect to SAP on-premise systems:
Install and register a Workato on-prem agent in your workspace.
Ensure the SAP system exposes the required OData services under the /WKTO/ namespace.
Verify network connectivity between the on-prem agent host and the SAP application server.
Connect without an on-prem agent ​
Whitelist Workato IP addresses on the SAP HTTPS port to allow inbound traffic from Workato. You can find the HTTPS port in transaction SMICM or SAP Web Dispatcher.
Ensure the SAP OData service endpoint remains externally accessible over HTTPS.
Configure the development environment (on-prem agent) ​
In development environments, you may disable certificate validation in the on-prem agent configuration to troubleshoot connectivity issues.
Edit the config.yml file in the OPA conf directory:
yaml
http:
  trustAll: true
  verifyHost: false
Refer to the On-prem agent HTTP profile documentation for more information about HTTP profile configuration options.
Use this configuration only in non-production environments.
Create and configure a data pipeline ​
After you install SAP Data Agent and establish connectivity, create a data pipeline to extract SAP table data.
Create the SAP OData connection ​
Complete the following steps to create the SAP OData connection:
Search for SAP OData and select it as your app.
Create an SAP OData connectionCreate an SAP OData connection
Complete the following fields in Workato to establish the SAP OData connection:
FieldDescription
Connection typeSelect the connection type based on your SAP deployment. Choose On-premise (through Secure Gateway) if your SAP instance runs on a network that doesn't allow direct external connections. Ensure you have an active on-prem agent before attempting to connect. Choose Cloud if SAP exposes OData services publicly. Requests are sent directly from Workato servers.
Authentication typeSelect Basic. Data pipelines support only basic authentication.
OData versionSelect OData V2.
UsernameEnter the username of the SAP Communication user (type C).
PasswordEnter the corresponding password.
Host URLEnter https://<hostname>/sap/opu/odata/ as the base path of the SAP OData services.
ServiceEnter WKTO/DA_CM_SRV as the OData service name configured in SAP.
SAP ClientEnter the SAP client used for login. For example, if your service URL is https://<hostname>/sap/opu/odata/WKTO/DA_CM_SRV?sap-client=800, enter 800. This field applies only to on-prem SAP systems.
Click Connect to validate the credentials and connection configuration.
Verify the following if the connection fails:
  • SAP credentials
  • Host URL format
  • Service name
  • Network accessibility
Common errors include 401 Unauthorized and Host unreachable.
Create a data pipeline ​
Complete the following steps to create a new data pipeline:
Click Start building.
Configure the SAP source ​
Complete the following steps to configure SAP as the source application:
Select SAP OData as the source application.
Choose the SAP OData connection to use for this pipeline. Alternatively, click + New connection to create a new connection.
Choose the SAP OData connectionChoose the SAP OData connection
Click Add object to select the SAP table to extract.
Add objectAdd object
Enter at least three uppercase characters of the SAP table name in the search field.
SAP table names are case-sensitive and use uppercase letters.
Select the tables from the search results.
Select SAP tablesSelect SAP tables
Click Add to confirm the selection.
CDS VIEWS
Search the SQL view name instead of the CDS view name for CDS views.
Define the schema ​
After you add the SAP table, the pipeline automatically fetches the schema for each selected object. Review and customize the schema to ensure the destination matches the source:
Click Get schema to retrieve table metadata.
Expand any table to view the list of available fields.
Keep all fields selected to extract all data, or deselect specific fields to exclude them from extraction and schema replication.
Optional. Configure field-level data protection for each non-key field:
  • Replicate as is (default): Data values at the source are replicated identically to the destination.
  • Hash: Hash sensitive data values in the column before syncing to your destination.
Click Add object again to add more objects using the same flow. You can repeat this step to include multiple SAP tables in your pipeline.
Configure advanced settings ​
Configure pipeline-level settings to control execution behavior and SAP system impact:
Adjust the Concurrency configuration.
Adjust the concurrency configurationAdjust the concurrency configuration
Concurrency defines how many pipeline jobs run simultaneously:
  • Higher values allow parallel executions and increase throughput.
  • Lower values reduce load on the SAP system and help prevent table locks or performance issues.
Adjust concurrency carefully to avoid excessive load on the SAP system.
Set the Frequency.
Configure frequencyConfigure frequency
Frequency defines how often the pipeline runs, such as every few minutes, hourly, or daily. Select a frequency that balances data freshness with SAP system performance and stability.
Choose either a standard time-based schedule or define a custom cron expression in the Frequency field. This determines how often the pipeline syncs data from SAP Table Reader to the destination.
Configure the destination ​
After you configure the SAP source and advanced settings, select the destination for your data.
Click the Load data to target table in destination app action. This action defines how the pipeline replicates data in the destination.
Configure destinationConfigure destination
Select the destination application.
Select an existing destination connection, or click + New connection to create one.
Click Save.
Refer to the following guides for destination-specific configuration details:
Start the pipeline ​
Click Start pipeline to begin data extraction.
Start pipelineStart pipeline
Workato sends extraction requests to SAP Data Agent, retrieves data in packages, and loads the data into the destination.
Review sync completion ​
After the pipeline finishes extracting data, SAP Data Agent performs post-extraction cleanup to protect system performance and data security.
Completed syncCompleted sync
The following occurs:
  • Workato makes the full dataset available in the pipeline for downstream processing.
  • Workato sends a final cleanup API call to SAP Data Agent.
  • The SAP Data Agent flushes pipeline execution memory and deletes temporary staging tables in the SAP system.
This cleanup process ensures efficient resource usage and prevents residual staging data from accumulating in SAP.
