Configure Xero as a data pipeline source ​
Set up Xero as a data pipeline source to extract accounting data, such as invoices, contacts, payments, and chart-of-accounts records, from the Xero Accounting API and sync it to your destination.
Use this guide to review the features and prerequisites, connect Xero as a data pipeline source, configure the pipeline, and understand the supported objects, sync modes, schema handling, sensitive data handling, and limitations.
Xero features supported ​
The following features are supported when you use Xero as a pipeline source:
  • Cloud connectivity: Connects to the Xero Accounting API over https. An on-prem agent isn't required.
  • Object-level selection: Choose the supported objects you plan to sync when you configure the pipeline.
  • Full sync and incremental sync: Supports full sync and incremental sync.
  • Multi-organization support: Each connection syncs one Xero organization. Create a separate pipeline for each organization you manage.
  • Schema drift detection and handling: Detect and apply schema changes automatically with Auto-sync new fields, or keep the schema fixed with Block new fields.
  • Field-level data protection: Hash or replicate sensitive fields as is before the data reaches your destination.
  • Configurable sync frequency: Schedule syncs on a time-based interval or with a cron expression. The minimum supported interval is 15 minutes.
Xero prerequisites ​
Complete the following requirements before you configure Xero as a data pipeline source:
  • A Xero account with access to the organization you plan to sync.
  • Permission to authorize a third-party application through the Xero OAuth flow.
SUBSCRIPTION AND MODULE REQUIREMENTS
Some objects require a specific Xero subscription or enabled module.
  • Multi-currency transaction fields and the currency object require the Established plan.
  • The project object requires the Established plan and the Projects add-on.
  • The fixed_asset object requires a non-Trial organization.
If your organization doesn't have access to an object because of its subscription, region, or module enablement, that object's sync fails with a permissions error. Remove the object from the pipeline to sync the remaining objects. Refer to Subscription and module requirements for more information.
Supported connection types ​
Xero data pipelines support OAuth 2.0 authentication:
  • OAuth 2.0: Authorizes Workato to read data from the Xero organizations your account can access. Workato requests read-only scopes and refreshes access tokens automatically for the life of the connection.
Xero supports OAuth 2.0 as its only authentication method for the Accounting API. Client credentials and custom connections aren't supported, because they don't support the multi-organization model that data pipelines use.
Connect to Xero ​
Complete the following steps to connect to Xero:
Connect to Xero
Search for Xero and select it as your app.
Use the Location drop-down menu to select the project or folder where you plan to store the connection.
Enter the exact Tenant name for the organization you plan to connect. This field is case-sensitive.
Optional. Use the Custom OAuth profile drop-down menu to select a custom OAuth profile for this connection.
Click Connect and sign in to Xero to authorize the connection.
Xero loginXero login
How to find different IDs in Xero
Each record in Xero has a unique identifier called a Xero ID. You can obtain these IDs using two primary methods:
Retrieving IDs directly from Xero ​
Go to the specific item's page in Xero and locate the ID at the end of the URL. This method suits scenarios requiring a consistent ID, typically during testing. For example:
Contact IDContact ID in the contact page URL
In this instance, the Contact ID is 46145141-500e-4a15-b2e1-2752708fdd52 and appears at the end of a contact's page URL in Xero. You can also find other IDs, such as the Manual journal ID, at the end of its page URL.
Using Workato actions to obtain IDs ​
You can also use Workato actions such as Search, Create, or Update to obtain Xero IDs. Workato retrieves the record's ID in the API response when it interacts with a Xero record. The following examples demonstrate this method:
  • Contact ID
  • Obtain the unique identifier for each contact in Xero using triggers and actions such as New/updated contact, Search contacts, and Upsert contact. For example, you can search for contacts by name or email and use the output datapill for the Contact ID.
Search for contactsSearch for contacts by name or email
Manual Journal IDSearch for manual journal ID
PaymentSearch for payment ID
Configure the pipeline ​
Complete the following steps to configure Xero as your data pipeline source:
Click Start building.
Click the Extract new/updated records from source app trigger. This trigger defines how the pipeline retrieves data from Xero.
Use the Your Connected Source Apps drop-down menu to select Xero.
Choose the Xero connection you plan to use for this pipeline. Alternatively, click + New connection to create a new connection.
Search or browse the list of available Xero objects, select the objects you plan to sync, and click Add.
SYNC MODE IS FIXED PER OBJECT
The sync mode is fixed for each object, based on whether the Xero API exposes a modification timestamp for it. Objects with a modification timestamp sync incrementally. Reference objects that provide no modification signal sync in full on every run. Refer to Sync modes for more information.
  • Replicate as is: Data values at the source replicate identically to the destination.
  • Hash: Hash sensitive data values in the field before syncing to your destination.
12
Click Add object again to add more objects. Repeat this step to include additional Xero objects in your pipeline.
13
14
Optional. Enter a value in the Concurrency limit field to limit the number of concurrent operations. The maximum value you can enter is 100. Workato applies workspace quotas and source quotas, including the Xero pipelines quota of 1 concurrent operation.
15
Choose either a standard time-based schedule or define a custom cron expression in the Frequency field. This determines how often the pipeline syncs data from Xero to the destination.
Supported Xero objects ​
Xero data pipelines sync data from the Xero Accounting API. The following tables list the supported objects, grouped by category. Each object syncs as a separate table in your destination.
Child and junction objects appear in your destination as separate normalized tables. You select and schedule each one independently, and the connector reads the parent object to build the rows.
The invoice, credit_note, bank_transaction, purchase_order, quote, and manual_journal objects sync their line items as separate child tables. The invoice, credit_note, and manual_journal line tables also sync their tracking-category assignments as a further child table.
Each child table uses a composite primary key that combines the parent identifier with the child key.
Transactions ​
The following objects describe the financial transactions in your organization and the line items and tracking categories attached to them:
ObjectSync modeDelete tracking
invoiceIncrementalYes (soft)
invoice_lineFull syncYes (destination-inferred)
invoice_line_tracking_categoryFull syncYes (destination-inferred)
credit_noteIncrementalYes (soft)
credit_note_lineFull syncYes (destination-inferred)
credit_note_line_tracking_categoryFull syncYes (destination-inferred)
bank_transactionIncrementalYes (soft)
bank_transaction_lineFull syncYes (destination-inferred)
paymentIncrementalYes (soft)
overpaymentIncrementalYes (soft)
prepaymentIncrementalYes (soft)
purchase_orderIncrementalYes (soft)
purchase_order_lineFull syncYes (destination-inferred)
quoteIncrementalYes (soft)
quote_lineFull syncYes (destination-inferred)
manual_journalIncrementalYes (soft)
manual_journal_lineFull syncYes (destination-inferred)
manual_journal_line_tracking_categoryFull syncYes (destination-inferred)
repeating_invoiceFull syncYes (soft)
linked_transactionFull syncYes (soft)
bank_transferIncrementalNo
Contacts ​
The following objects describe the contacts in your organization and the groups they belong to:
contactIncrementalYes (soft)
contact_groupFull syncYes (destination-inferred)
contact_group_membershipFull syncYes (destination-inferred)
Accounting settings and reference data ​
The following objects describe the chart of accounts and the reference data that transactions refer to:
accountIncrementalYes (soft)
itemIncrementalYes (soft)
tax_rateFull syncYes (soft)
currencyFull syncYes (destination-inferred)
tracking_categoryFull syncYes (soft)
tracking_category_optionFull syncYes (soft)
branding_themeFull syncYes (destination-inferred)
budgetFull syncYes (destination-inferred)
organisationFull syncYes (destination-inferred)
userIncrementalNo
Assets and projects ​
The following objects require a specific Xero module or add-on:
fixed_assetFull syncYes (soft)
projectFull syncYes (soft)
Primary keys ​
Root objects use a single-column id primary key. Child and junction tables use a composite primary key that combines the parent identifier with the child key:
ObjectPrimary key
invoice_line, credit_note_line, bank_transaction_line, purchase_order_line, quote_lineParent ID, id
manual_journal_linemanual_journal_id, line_number
invoice_line_tracking_category, credit_note_line_tracking_category, manual_journal_line_tracking_categoryParent ID, parent line ID, tracking_category_id
contact_group_membershipcontact_group_id, contact_id
tracking_category_optiontracking_category_id, id
Sync modes ​
Xero data pipelines support full sync and incremental sync. The sync mode is fixed for each object, based on whether the object exposes a modification timestamp.
Full sync ​
Full sync reads all available records for an object from Xero on each run. The pipeline uses full sync for reference objects that provide no modification signal, such as tax_rate, currency, tracking_category, and branding_theme.
Objects with a primary key merge into the existing destination table, so records deleted in Xero stay in the table. Objects without a primary key overwrite the destination table on every run.
Incremental sync ​
Incremental sync reads only the records created or updated since the previous run. Each incremental object tracks its progress using a modification timestamp, which is updated_date_utc for most objects and created_date_utc for bank_transfer. The pipeline stores the highest timestamp it observes and uses it as the starting point for the next run.
Refer to the Supported objects tables to see the sync mode for each object.
Delete tracking ​
Xero doesn't have a native delete log, so the pipeline detects deletions in two ways:
  • Source-driven soft delete: Transaction, contact, account, item, tracking category, tax rate, fixed asset, and project objects carry a status, archive, or disposal field. The pipeline reads these fields and sets _workato_is_deleted on the destination row. These objects are marked Yes (soft). Invoices, credit notes, and manual journals are marked deleted when their status is DELETED or VOIDED; purchase orders, quotes, payments, and repeating invoices when their status is DELETED; overpayments, prepayments, and linked transactions when voided; accounts, tracking categories, and tax rates when archived or deleted; contacts when deleted or archived; items when archived; fixed assets when disposed; and projects when closed.
  • Destination-inferred delete: Full-sync objects re-read the complete record set on each run. The destination compares each run against the previous one and sets _workato_is_deleted to true for records that are no longer present, so deletions are tracked without a source-side marker. These objects are marked Yes (destination-inferred) in the Supported objects tables.
The user and bank_transfer objects sync incrementally and expose no status or archive field, so the pipeline can't detect deletions for them. These objects are marked No.
Soft-delete detection for manual_journal and linked_transaction is an optimized effort and not exact. Xero's APIs don't provide an unbounded way to request all deleted manual journals or all voided linked transactions, so some source-side deletions may not be returned for the connector to mark.
Schema and data type handling ​
The connector applies specific handling to certain Xero field types when it replicates data to your destination.
Timestamps and dates ​
Xero returns most timestamps in a .NET date format. The connector converts these values to ISO 8601 UTC before writing them to your destination. Date-only fields that have no time component, such as date, due_date, and fully_paid_on_date, are stored as DATE rather than TIMESTAMP.
Multi-currency fields ​
Your organization can enable multi-currency to include currency_code and currency_rate fields on transactions and list enabled currencies in the currency object.
Synthetic columns ​
Workato adds the following synthetic columns to destination tables:
ColumnTypePurpose
_workato_is_deletedBooleanMarks a record that the pipeline detected as deleted, voided, archived, or no longer present at the source. Added to every object you sync in full sync mode. In incremental mode, added only to objects with a source-driven soft-delete signal.
_workato_run_idStringIdentifies the pipeline run that last wrote the row. The destination uses this to detect rows that no longer exist in Xero.
_workato_synced_atTimestampWhen the pipeline last wrote the row to your destination.
Column name casing in your destination ​
Your destination adjusts column name casing when it creates tables. Snowflake stores column names in uppercase, most destinations store them in lowercase, and BigQuery and SQL Server keep them as the connector emits them.
Sensitive data handling ​
Xero objects can contain personally identifiable information (PII) and sensitive financial data. The following objects commonly contain sensitive fields:
ObjectSensitive fields
contactname, first_name, last_name, email_address, tax_number, bank_account_details, account_number, website
userfirst_name, last_name, email_address, organisation_role
manual_journalnarration
The contact object carries the highest risk, because it includes bank account details, tax numbers, and full contact records. The narration field on manual_journal is free-text and can contain employee names or payment references. Invoices, credit notes, and other transaction objects reference contacts by contact_id rather than storing contact names or email addresses. Hash the sensitive fields on the contact object and join on contact_id to protect this data.
Workato recommends hashing contact and user PII for pipelines operating under the GDPR, the CCPA, or the Australian Privacy Act.
Xero limitations ​
The following limitations apply when you use Xero as a data pipeline source:
Multi-currency gains and losses ​
The Xero API doesn't expose unrealized currency gains and losses or bank revaluations as discrete records. Reports that depend on these values can't be reconstructed from the synced data alone.
Subscription and module requirements ​
Certain objects require a specific Xero subscription or enabled module:
ObjectRequirement
currency and multi-currency transaction fieldsEstablished plan
projectEstablished plan and the Projects add-on
fixed_assetA non-Trial organization
Minimum sync frequency ​
The minimum sync interval is 15 minutes by default.
