Set up HashiCorp Vault secrets engines for workspaces
Switching to workspace-specific secrets management causes all previously configured external secret references to stop working.
Prerequisites
To complete the steps in this guide, you must have the following:
  • HashiCorp Vault Key-value (KV) secrets engine version 1 or 2.
  • An account with AppRole auth method enabled.
  • One or more AppRoles configured.
Select the scope for secrets management
Sign in to Workato.
Go to Workspace admin > Settings > External secrets manager.
Select the Set up secrets management for the entire workspace option from the Scope drop-down menu.
Workato secrets management, selecting workspace scope
Select the secrets manager
Select HashiCorp Vault from the Which secrets manager do you want to use? drop-down menu.
Hashicorp Vault secrets
Configure the connection in Workato
Configure connectionConnect to HashiCorp Vault
  • Connection name
  • Name your HashiCorp Vault connection.
  • Connection type
  • To connect to HashiCorp Vault using an on-prem group, select the group name from the drop-down menu. Otherwise, to use a direct connection, select Cloud.
  • Authentication type
  • Select AppRole from the drop-down.
  • Vault URL
  • Enter the Vault URL of your Hashicorp Vault instance. It should follow this form https://<instance_name>.<company_name>.com:123.
    • instance_name
    • The name of your HashiCorp Vault instance.
    • company_name
    • The name of your organization.
  • Namespace
  • Optional. The name of the namespace that contains the secret(s) you plan to use in Workato. Namespaces are a set of features that enable you to define granular control and secrets management within your organization.
    In our example, we grant Workato access to the admin/HR namespace.
  • AppRole name
  • The AppRole you plan to use. An AppRole is a set of Vault policies and login constraints that determines which secrets you can access.
Obtain the AppRole ID and AppRole Secret ID from HashiCorp Vault
AppRole is a login credential split into two parts- the AppRole ID and AppRole Secret ID. You must obtain both to authenticate to Workato. The AppRole ID can be considered similar to a username- its value remains constant and associated with its corresponding AppRole. On the contrary, the AppRole Secret ID is similar to a password or unique key and you can prompt HashiCorp Vault to refresh this credential, if needed.
In HashiCorp Vault click >_ to open the control panel.
Command iconOpen the control panel
Enter the following command:
vault read auth/<approle_name>/role/<role_name>/role-id
  • <approle_name>
  • The AppRole you have configured in HashiCorp Vault.
  • <role_name>
  • The name of the Workato role you plan to connect to.
Example:
vault read auth/workato_approle/role/workato/role-id
HashiCorp Vault returns the AppRole ID unique to your AppRole:
Key     Value
role_id 12a3bc45-6de7-8910-11fg-h4ij12XXXXXX
Copy and paste this value into the AppRole ID field in Workato.
Obtain the AppRole Secret ID by entering the following command to the control panel in HashiCorp Vault:
vault write -force auth/<approle_name>/role/<role_name>/secret-id
Example:
vault write -force auth/workato_approle/role/workato/secret-id
HashiCorp Vault generates an AppRole Secret ID for your AppRole:
Key                 Value
secret_id           ed0a642f-2acf-c2da-232f-1b2130XXXXXX
secret_id_accessor  a240a31f-270a-4765-64bd-94ba1fXXXXXX
Copy and paste the secret_id value into the AppRole Secret ID field in Workato.
Click Connect. Workato displays the name of the HashiCorp Vault connection:
Connection successfulConnection successful
