# 422 Unprocessable Entity
The 422 Unprocessable Entity error occurs when the external service receives a request but can't process it due to issues with the input data. This typically means the request contains invalid values, is missing required data, or includes values that conflict with existing data.
Example of 422 Unprocessable Entity error
# Why it happens
The following issues often trigger a 422 Unprocessable Entity error in Workato:
- The recipe tries to create a record with a value that already exists for a unique field, such as an email or ID.
- The recipe tries to update a record that doesn't exist.
- The recipe uses reference IDs that don't match any existing records.
- The request leaves a required field blank or includes an invalid value.
# How to troubleshoot
Complete the following steps to resolve the error:
Check for conflicts in unique fields. If you create a record, ensure the value, such as an email or ID, doesn't already exist in the external app.
Verify that the record exists before you run an Update record action. If the record is missing, create it first.
Use only valid reference IDs. For example, if you assign a Salesforce lead to a sales representative, ensure the sales representative exists in Salesforce.
Populate all required fields. Don't leave required fields blank.
Contact Workato support (opens new window) if the issue persists.
Last updated: 7/9/2025, 8:45:36 PM
