Developer API - Connectors ​
Use these API endpoints to obtain information about standard Workato connectors. This is useful if you plan to generate a marketplace of apps.
Rate limits ​
Connector resources have the following rate limit:
TypeResourceQuota
AllAll Connectors endpoints60 requests per minute
Quick reference ​
TypeResourceDescription
GET/api/integrationsReturns a list of connectors and metadata specified in request.
GET/api/integrations/allReturns a paginated list of all connectors and associated metadata in a non-embedded workspace. The response includes standard and platform connectors.
List connector metadata ​
Returns a list of connectors and associated metadata specified in the API request.
GET https://YOUR_DATA_CENTER/api/integrations
Payload ​
NameTypeDescription
applicationsstring
required
Comma separated connector identifiers.
Sample request ​
shell
curl  -X GET https://YOUR_DATA_CENTER/api/integrations \
      -d '{
            "applications": ":applications"
Sample response ​
View a sample response
json
    "items": [
            "name": "google_drive",
            "title": "Google Drive",
            "categories": [
                "Document/File",
                "Sales Enablement"
            "oauth": true,
            "deprecated": false,
            "secondary": false,
            "triggers": [
                    "name": "new_file_in_subfolder",
                    "title": "New file or folder in folder hierarchy",
                    "bulk": false,
                    "batch": false
                    "name": "new_file_or_folder",
                    "title": "New file or folder",
                    "bulk": false,
                    "batch": false
            "actions": [
                    "name": "__adhoc_http_action",
                    "title": "Custom action",
                    "bulk": false,
                    "batch": false
                    "name": "create_folder",
                    "title": "Create folder",
                    "bulk": false,
                    "batch": false
                    "name": "download_file_contents",
                    "title": "Download file",
                    "bulk": false,
                    "batch": false
                    "name": "move_rename_file",
                    "title": "Rename or move file/folder",
                    "bulk": false,
                    "batch": false
                    "name": "search_file_or_folder",
                    "title": "Search files or folders",
                    "bulk": false,
                    "batch": false
                    "name": "upload_file",
                    "title": "Upload small file",
                    "bulk": false,
                    "batch": false
                    "name": "upload_file_stream",
                    "title": "Upload large file",
                    "bulk": false,
                    "batch": false
            "name": "service_now",
            "title": "ServiceNow",
            "categories": [
                "Customer Service",
                "IT Service Management"
            "oauth": true,
            "secondary": false,
            "triggers": [
                    "name": "closed_incident",
                    "title": "Closed incident",
                    "deprecated": true,
                    "bulk": false,
                    "batch": false
                    "name": "new_incident",
                    "title": "New incident",
                    "deprecated": true,
                    "bulk": false,
                    "batch": false
                    "name": "new_object",
                    "title": "New record",
                    "bulk": false,
                    "batch": false
                    "name": "new_object_webhook",
                    "bulk": false,
                    "batch": false
                    "name": "new_sys_user",
                    "title": "New user",
                    "deprecated": true,
                    "bulk": false,
                    "batch": false
                    "name": "scheduled_query",
                    "title": "Scheduled record search",
                    "bulk": false,
                    "batch": true
                    "name": "updated_incident",
                    "title": "New/updated incident",
                    "deprecated": true,
                    "bulk": false,
                    "batch": false
                    "name": "updated_object",
                    "title": "New/updated record",
                    "bulk": false,
                    "batch": false
                    "name": "updated_object_webhook",
                    "bulk": false,
                    "batch": false
                    "name": "updated_sys_user",
                    "title": "New/updated user",
                    "deprecated": true,
                    "bulk": false,
                    "batch": false
            "actions": [
                    "bulk": false,
                    "batch": false
                    "name": "assign_user_to_incident",
                    "title": "Assign user to incident",
                    "deprecated": true,
                    "bulk": false,
                    "batch": false
                    "name": "create_asset",
                    "title": "Create asset",
                    "deprecated": true,
                    "bulk": false,
                    "batch": false
                    "name": "create_catalog_task",
                    "title": "Create catalog task",
                    "deprecated": true,
                    "bulk": false,
                    "batch": false
                    "name": "create_change",
                    "title": "Create change",
                    "deprecated": true,
                    "bulk": false,
                    "batch": false
                    "name": "create_core_company",
                    "title": "Create core company",
                    "deprecated": true,
                    "bulk": false,
                    "batch": false
                    "name": "create_incident",
                    "title": "Create incident",
                    "deprecated": true,
                    "bulk": false,
                    "batch": false
                    "name": "create_object",
                    "title": "Create record",
                    "bulk": false,
                    "batch": false
                    "name": "create_object_using_template",
                    "title": "Create record using a template",
                    "bulk": false,
                    "batch": false
                    "name": "create_problem",
                    "title": "Create problem",
                    "deprecated": true,
                    "bulk": false,
                    "batch": false
                    "name": "create_user",
                    "title": "Create user",
                    "deprecated": true,
                    "bulk": false,
                    "batch": false
                    "name": "get_incident",
                    "title": "Get incident details by ID",
                    "deprecated": true,
                    "bulk": false,
                    "batch": false
                    "name": "get_user",
                    "title": "Get user details by ID",
                    "deprecated": true,
                    "bulk": false,
                    "batch": false
                    "name": "lookup_user",
                    "title": "Search users",
                    "deprecated": true,
                    "bulk": false,
                    "batch": false
                    "name": "search_assets",
                    "title": "Search assets",
                    "deprecated": true,
                    "bulk": false,
                    "batch": false
                    "name": "search_companies",
                    "title": "Search companies",
                    "deprecated": true,
                    "bulk": false,
                    "batch": false
                    "name": "search_objects",
                    "title": "Search records",
                    "deprecated": true,
                    "bulk": false,
                    "batch": false
                    "name": "search_objects_v2",
                    "bulk": false,
                    "batch": false
                    "name": "search_users",
                    "deprecated": true,
                    "bulk": false,
                    "batch": false
                    "name": "search_using_query",
                    "title": "Search records using query",
                    "bulk": false,
                    "batch": false
                    "name": "update_asset",
                    "title": "Update asset",
                    "deprecated": true,
                    "bulk": false,
                    "batch": false
                    "name": "update_company",
                    "title": "Update company",
                    "deprecated": true,
                    "bulk": false,
                    "batch": false
                    "name": "update_incident",
                    "title": "Update incident",
                    "deprecated": true,
                    "bulk": false,
                    "batch": false
                    "name": "update_object",
                    "title": "Update record",
                    "bulk": false,
                    "batch": false
                    "name": "update_object_using_template",
                    "title": "Update record using a template",
                    "bulk": false,
                    "batch": false
                    "name": "update_user",
                    "title": "Update user",
                    "deprecated": true,
                    "bulk": false,
                    "batch": false
List all platform connectors ​
Returns a paginated list of all connectors and associated metadata in a non-embedded workspace. This includes both standard and platform connectors. Workato includes the total number of records at the end of the response.
GET https://YOUR_DATA_CENTER/api/integrations/all
Query parameters ​
NameTypeDescription
pageinteger
optional
Page number. Defaults to 1. If the total number of connectors exceeds the record per page quota, call the next page to retrieve subsequent pages.
per_pageinteger
optional
Number of records per page. Defaults to 1 and has a maximum of 100. If you enter more than 100, Workato only returns 100 records in the response.
Sample request ​
shell
curl  -X GET https://YOUR_DATA_CENTER/api/integrations/all?page=:page_value&per_page=:per_page_value \
Response ​
json
    "count": 293,
    "page": 1,
    "per_page": 90
ABRIDGED RESPONSE
The preceding response is abridged to display the total record count returned in the response. For an example of the connectors and associated metadata Workato returns for each record, see the list connector metadata API.
