Developer API - Cross-workspace sharing
The following endpoints enable you to manage cross-workspace grants programmatically.
Grants are two-sided. Outgoing grants are the grants your workspace shares out, and they support full management operations. Incoming grants are the grants other workspaces share with your workspace, and they are read-only. The source and target environment endpoints help a client discover valid environments before it creates a grant. Every call is scoped to the caller's own workspace.
REQUIRED PRIVILEGES
Your API client's role must include the relevant privileges under Admin > Cross-workspace sharing in the API client role editor. The Cross-workspace sharing grants feature contains the outgoing grant and environment discovery privileges. The Cross-workspace sharing incoming grants feature contains the List incoming grants and View incoming grant privileges.
Rate limits
Cross-workspace sharing developer API resources have the following rate limits:
| Type | Resource | Quota |
| Read | All read Cross-workspace sharing endpoints | 600 requests per minute |
| Write | All write Cross-workspace sharing endpoints | 60 requests per minute |
Quick reference
| GET | /api/cross_workspace/grants | Retrieve a list of outgoing grants. |
| GET | /api/cross_workspace/grants/:handle | Get an outgoing grant by handle. |
| POST | /api/cross_workspace/grants | Create a grant. |
| PUT | /api/cross_workspace/grants/:handle | Update a grant. |
| DELETE | /api/cross_workspace/grants/:handle | Revoke a grant. |
| GET | /api/cross_workspace/incoming_grants | Retrieve a list of incoming grants. |
| GET | /api/cross_workspace/incoming_grants/:handle | Get an incoming grant by handle. |
| GET | /api/cross_workspace/source_environments | Retrieve environments that can act as a grant source. |
| GET | /api/cross_workspace/target_environments | Retrieve environments grantable from a given source. |
How the API references environments and assets
The cross-workspace sharing API uses the following identifiers and conventions:
Grants
Each grant is identified by a unique string
handle, such ascwsgr-2f8h1k-a3x9qz-1. A single grant can share from multiple source environments at once. Theenvironmentsarray carries one entry for each source environment.Environments
Environments are referenced by their internal
id. A grant shares from asource_environment_idin your own workspace to one or moretarget_environment_ids. Targets must be same-type siblings of the source, so aprodsource shares toprodtargets, in the same Automation HQ organization and the same data center. Use the List source environments and List target environments endpoints to discover valid IDs before you create a grant.Assets
Assets are referenced by
idandtype. Cross-workspace sharing supports Event streams topics, sotypeisTopic. The assetidis the topic's ID, the same identifier the Event streams API uses. This API represents the assetidas a string even though the Event streams topic ID is an integer, because cross-workspace sharing is designed to accommodate future asset types whose IDs aren't numbers. Quote the ID when you use it here.Access levels
The
access_levelsarray grants one or both ofreadandwritefor an asset. These map to the Subscribe and Publish access levels shown in the cross-workspace sharing UI. Both outgoing and incoming grants represent access levels as an array.
List outgoing grants
Retrieves a list of grants owned by the caller's workspace, with optional name filtering and sorting.
GET /api/cross_workspace/grantsQuery parameters
| Name | Type | Description |
| name | string optional | Filters grants by a partial, case-insensitive match on name. |
| sort | string optional | Defines how to sort the results. Options include name, -name, updated_at, and -updated_at. A - prefix sorts descending. Set to updated_at descending by default. |
| page[number] | integer optional | The page number to retrieve. The default value is 1. |
| page[size] | integer optional | The number of grants per page to retrieve. The default and maximum value is 100. |
Sample request
This request retrieves outgoing grants that match the name Orders, sorted by name.
curl -g -X GET "https://app.workato.com/api/cross_workspace/grants?name=Orders&sort=name&page[number]=1&page[size]=100" \
-H 'Authorization: Bearer <api_token>'Response
"data": [
"handle": "cwsgr-2f8h1k-a3x9qz-1",
"name": "Orders topic to EU and APAC",
"description": "Share prod orders stream",
"created_by": { "name": "Sasha Patel" },
"created_at": "2026-06-30T12:00:00.000Z",
"updated_at": "2026-06-30T12:00:00.000Z",
"environments": [
"source_environment_id": 123,
"source_environment_type": "prod",
"target_environments": [
{ "id": 456, "type": "prod", "workspace_id": 17293, "workspace_name": "Acme EU" }
"assets": [
{ "id": "48213", "name": "orders", "type": "Topic", "access_levels": ["read", "write"] }
"total": 42,
"page": { "number": 1, "size": 100 }
}Get an outgoing grant
Retrieves a single grant owned by the caller's workspace, resolved by handle.
GET /api/cross_workspace/grants/:handleURL parameters
| handle | string required | The grant's handle. |
Sample request
This request retrieves the grant with the handle cwsgr-2f8h1k-a3x9qz-1.
curl -X GET "https://app.workato.com/api/cross_workspace/grants/cwsgr-2f8h1k-a3x9qz-1" \
"data": {
"environments": [
"assets": [
}A grant that isn't owned by the caller's workspace returns 404.
Create a grant
Creates a grant in the caller's workspace.
POST /api/cross_workspace/grantsBody parameters
| name | string required | The grant's name. |
| description | string optional | The grant's description. |
| environments | array optional | One entry for each source environment you share from. Omit environments to create an empty grant that you populate later with an update. |
| environments[source_environment_id] | integer required | The source environment's ID. Must belong to the caller's workspace. |
| environments[target_environment_ids] | array optional | The IDs of the target environments to share to. Must be same-type siblings of the source, in the same Automation HQ organization. |
| environments[assets] | array optional | The assets shared from this source environment. |
| environments[assets][id] | string required | The asset's ID, provided as a string. For Event streams topics, use the topic's ID. |
| environments[assets][type] | string required | The asset's type. Accepts Topic. |
| environments[assets][access_levels] | array required | The access levels granted for the asset. One or both of read and write. |
Sample request
This request creates a grant that shares the orders topic from source environment 123 with two target environments.
curl -X POST "https://app.workato.com/api/cross_workspace/grants" \
-d '{
"environments": [
"target_environment_ids": [456, 789],
"assets": [
{ "id": "48213", "type": "Topic", "access_levels": ["read", "write"] }
}'Response
"data": {
"environments": [
{ "id": 456, "type": "prod", "workspace_id": 17293, "workspace_name": "Acme EU" },
{ "id": 789, "type": "prod", "workspace_id": 40021, "workspace_name": "Acme APAC" }
"assets": [
}This endpoint returns 201 on success. It returns 400 if the body fails validation, including a target_environment_id equal to its own source, a target of a different environment type or outside the source's Automation HQ organization, or an asset not owned by its source environment. Each rule reports its own message, so a request that fails more than one rule receives one message for each failing rule.
Update a grant
Updates a grant owned by the caller's workspace. The request accepts the same body shape as Create a grant, applied as a partial update for each source environment. Each environments entry is a partial slice keyed by source_environment_id. An omitted target_environment_ids or assets leaves that side unchanged, and an explicit empty array clears it.
PUT /api/cross_workspace/grants/:handleURL parameters
Body parameters
The request accepts the same fields as the Create a grant endpoint and applies them as a partial update to each source environment. The name field is optional on update. Omit it to leave the grant's name unchanged.
Sample request
This request updates the grant with the handle cwsgr-2f8h1k-a3x9qz-1 to share source environment 123 with a single target environment.
curl -X PUT "https://app.workato.com/api/cross_workspace/grants/cwsgr-2f8h1k-a3x9qz-1" \
-d '{
"name": "Orders topic to EU only",
"environments": [
{ "source_environment_id": 123, "target_environment_ids": [456] }
}'Response
"data": {
"updated_at": "2026-07-21T09:10:00.000Z",
"environments": [
"assets": [
}This endpoint returns 200 on success. It returns 404 if the handle isn't owned by the caller's workspace, and 400 on validation failure.
Revoke a grant
Soft-deletes a grant owned by the caller's workspace.
DELETE /api/cross_workspace/grants/:handleURL parameters
Sample request
This request revokes the grant with the handle cwsgr-2f8h1k-a3x9qz-1.
curl -X DELETE "https://app.workato.com/api/cross_workspace/grants/cwsgr-2f8h1k-a3x9qz-1" \
This endpoint returns 204 No Content with an empty body on success. It returns 404 if the handle isn't owned by the caller's workspace, and 400 if the deletion fails.
Retrieves a list of grants that target the caller's workspace. The list view is lightweight. Each source_environments entry carries a has_assets boolean instead of the full asset list. Use the Get an incoming grant endpoint to retrieve the full asset list for a grant.
GET /api/cross_workspace/incoming_grantsQuery parameters
Sample request
This request retrieves the grants that target your workspace.
curl -g -X GET "https://app.workato.com/api/cross_workspace/incoming_grants?page[number]=1&page[size]=100" \
"data": [
"source_workspace": { "id": 8842, "name": "Acme Global" },
"source_environments": [
{ "id": 123, "type": "prod", "has_assets": true }
"total": 3,
}Get an incoming grant
Retrieves a single grant that targets the caller's workspace. The single-grant view lists the shared assets for each source environment, including their access_levels.
GET /api/cross_workspace/incoming_grants/:handleURL parameters
Sample request
This request retrieves the incoming grant with the handle cwsgr-2f8h1k-a3x9qz-1.
curl -X GET "https://app.workato.com/api/cross_workspace/incoming_grants/cwsgr-2f8h1k-a3x9qz-1" \
"data": {
"id": 123,
"type": "prod",
"assets": [
{ "id": "48213", "name": "orders", "type": "Topic", "access_levels": ["read"] }
}A handle that doesn't target the caller's workspace returns 404.
Retrieves the caller workspace's environments that can act as a grant source.
GET /api/cross_workspace/source_environmentsSample request
This request retrieves the environments that can act as a grant source.
curl -X GET "https://app.workato.com/api/cross_workspace/source_environments" \
"data": [
{ "id": 123, "type": "prod", "name": "Acme Global (prod)" },
{ "id": 124, "type": "test", "name": "Acme Global (test)" }
}List target environments
Retrieves the sibling environments a given source environment can grant to. Targets are in the same Automation HQ organization and the same data center, and share the same environment type as the source.
GET /api/cross_workspace/target_environmentsQuery parameters
| source_environment_id | integer required | The source environment's ID. Must belong to the caller's workspace. |
Sample request
This request retrieves the environments grantable from source environment 123.
curl -X GET "https://app.workato.com/api/cross_workspace/target_environments?source_environment_id=123" \
"data": [
}This endpoint returns 400 if source_environment_id is omitted, and 404 if it doesn't belong to the caller's workspace.
