Developer API - Cross-workspace sharing ​
The following endpoints enable you to manage cross-workspace grants programmatically.
Grants are two-sided. Outgoing grants are the grants your workspace shares out, and they support full management operations. Incoming grants are the grants other workspaces share with your workspace, and they are read-only. The source and target environment endpoints help a client discover valid environments before it creates a grant. Every call is scoped to the caller's own workspace.
REQUIRED PRIVILEGES
Your API client's role must include the relevant privileges under Admin > Cross-workspace sharing in the API client role editor. The Cross-workspace sharing grants feature contains the outgoing grant and environment discovery privileges. The Cross-workspace sharing incoming grants feature contains the List incoming grants and View incoming grant privileges.
Rate limits ​
Cross-workspace sharing developer API resources have the following rate limits:
TypeResourceQuota
ReadAll read Cross-workspace sharing endpoints600 requests per minute
WriteAll write Cross-workspace sharing endpoints60 requests per minute
Quick reference ​
TypeResourceDescription
GET/api/cross_workspace/grantsRetrieve a list of outgoing grants.
GET/api/cross_workspace/grants/:handleGet an outgoing grant by handle.
POST/api/cross_workspace/grantsCreate a grant.
PUT/api/cross_workspace/grants/:handleUpdate a grant.
DELETE/api/cross_workspace/grants/:handleRevoke a grant.
GET/api/cross_workspace/incoming_grantsRetrieve a list of incoming grants.
GET/api/cross_workspace/incoming_grants/:handleGet an incoming grant by handle.
GET/api/cross_workspace/source_environmentsRetrieve environments that can act as a grant source.
GET/api/cross_workspace/target_environmentsRetrieve environments grantable from a given source.
How the API references environments and assets ​
The cross-workspace sharing API uses the following identifiers and conventions:
  • Grants
  • Each grant is identified by a unique string handle, such as cwsgr-2f8h1k-a3x9qz-1. A single grant can share from multiple source environments at once. The environments array carries one entry for each source environment.
  • Environments
  • Environments are referenced by their internal id. A grant shares from a source_environment_id in your own workspace to one or more target_environment_ids. Targets must be same-type siblings of the source, so a prod source shares to prod targets, in the same Automation HQ organization and the same data center. Use the List source environments and List target environments endpoints to discover valid IDs before you create a grant.
  • Assets
  • Assets are referenced by id and type. Cross-workspace sharing supports Event streams topics, so type is Topic. The asset id is the topic's ID, the same identifier the Event streams API uses. This API represents the asset id as a string even though the Event streams topic ID is an integer, because cross-workspace sharing is designed to accommodate future asset types whose IDs aren't numbers. Quote the ID when you use it here.
  • Access levels
  • The access_levels array grants one or both of read and write for an asset. These map to the Subscribe and Publish access levels shown in the cross-workspace sharing UI. Both outgoing and incoming grants represent access levels as an array.
List outgoing grants ​
Retrieves a list of grants owned by the caller's workspace, with optional name filtering and sorting.
shell
GET /api/cross_workspace/grants
Query parameters ​
NameTypeDescription
namestring
optional
Filters grants by a partial, case-insensitive match on name.
sortstring
optional
Defines how to sort the results. Options include name, -name, updated_at, and -updated_at. A - prefix sorts descending. Set to updated_at descending by default.
page[number]integer
optional
The page number to retrieve. The default value is 1.
page[size]integer
optional
The number of grants per page to retrieve. The default and maximum value is 100.
Sample request ​
This request retrieves outgoing grants that match the name Orders, sorted by name.
shell
curl  -g -X GET "https://app.workato.com/api/cross_workspace/grants?name=Orders&sort=name&page[number]=1&page[size]=100" \
Response ​
json
    "data": [
            "handle": "cwsgr-2f8h1k-a3x9qz-1",
            "name": "Orders topic to EU and APAC",
            "description": "Share prod orders stream",
            "created_by": { "name": "Sasha Patel" },
            "created_at": "2026-06-30T12:00:00.000Z",
            "updated_at": "2026-06-30T12:00:00.000Z",
            "environments": [
                    "source_environment_id": 123,
                    "source_environment_type": "prod",
                    "target_environments": [
                        { "id": 456, "type": "prod", "workspace_id": 17293, "workspace_name": "Acme EU" }
                    "assets": [
                        { "id": "48213", "name": "orders", "type": "Topic", "access_levels": ["read", "write"] }
    "total": 42,
    "page": { "number": 1, "size": 100 }
Get an outgoing grant ​
Retrieves a single grant owned by the caller's workspace, resolved by handle.
shell
GET /api/cross_workspace/grants/:handle
URL parameters ​
NameTypeDescription
handlestring
required
The grant's handle.
Sample request ​
This request retrieves the grant with the handle cwsgr-2f8h1k-a3x9qz-1.
shell
curl  -X GET "https://app.workato.com/api/cross_workspace/grants/cwsgr-2f8h1k-a3x9qz-1" \
Response ​
json
    "data": {
        "environments": [
                "assets": [
A grant that isn't owned by the caller's workspace returns 404.
Create a grant ​
Creates a grant in the caller's workspace.
shell
POST /api/cross_workspace/grants
Body parameters ​
NameTypeDescription
namestring
required
The grant's name.
descriptionstring
optional
The grant's description.
environmentsarray
optional
One entry for each source environment you share from. Omit environments to create an empty grant that you populate later with an update.
environments[source_environment_id]integer
required
The source environment's ID. Must belong to the caller's workspace.
environments[target_environment_ids]array
optional
The IDs of the target environments to share to. Must be same-type siblings of the source, in the same Automation HQ organization.
environments[assets]array
optional
The assets shared from this source environment.
environments[assets][id]string
required
The asset's ID, provided as a string. For Event streams topics, use the topic's ID.
environments[assets][type]string
required
The asset's type. Accepts Topic.
environments[assets][access_levels]array
required
The access levels granted for the asset. One or both of read and write.
Sample request ​
This request creates a grant that shares the orders topic from source environment 123 with two target environments.
shell
curl  -X POST "https://app.workato.com/api/cross_workspace/grants" \
      -d '{
            "environments": [
                    "target_environment_ids": [456, 789],
                    "assets": [
                        { "id": "48213", "type": "Topic", "access_levels": ["read", "write"] }
Response ​
json
    "data": {
        "environments": [
                    { "id": 456, "type": "prod", "workspace_id": 17293, "workspace_name": "Acme EU" },
                    { "id": 789, "type": "prod", "workspace_id": 40021, "workspace_name": "Acme APAC" }
                "assets": [
This endpoint returns 201 on success. It returns 400 if the body fails validation, including a target_environment_id equal to its own source, a target of a different environment type or outside the source's Automation HQ organization, or an asset not owned by its source environment. Each rule reports its own message, so a request that fails more than one rule receives one message for each failing rule.
Update a grant ​
Updates a grant owned by the caller's workspace. The request accepts the same body shape as Create a grant, applied as a partial update for each source environment. Each environments entry is a partial slice keyed by source_environment_id. An omitted target_environment_ids or assets leaves that side unchanged, and an explicit empty array clears it.
shell
PUT /api/cross_workspace/grants/:handle
URL parameters ​
NameTypeDescription
handlestring
required
The grant's handle.
Body parameters ​
The request accepts the same fields as the Create a grant endpoint and applies them as a partial update to each source environment. The name field is optional on update. Omit it to leave the grant's name unchanged.
Sample request ​
This request updates the grant with the handle cwsgr-2f8h1k-a3x9qz-1 to share source environment 123 with a single target environment.
shell
curl  -X PUT "https://app.workato.com/api/cross_workspace/grants/cwsgr-2f8h1k-a3x9qz-1" \
      -d '{
            "name": "Orders topic to EU only",
            "environments": [
                { "source_environment_id": 123, "target_environment_ids": [456] }
Response ​
json
    "data": {
        "updated_at": "2026-07-21T09:10:00.000Z",
        "environments": [
                "assets": [
This endpoint returns 200 on success. It returns 404 if the handle isn't owned by the caller's workspace, and 400 on validation failure.
Revoke a grant ​
Soft-deletes a grant owned by the caller's workspace.
shell
DELETE /api/cross_workspace/grants/:handle
URL parameters ​
NameTypeDescription
handlestring
required
The grant's handle.
Sample request ​
This request revokes the grant with the handle cwsgr-2f8h1k-a3x9qz-1.
shell
curl  -X DELETE "https://app.workato.com/api/cross_workspace/grants/cwsgr-2f8h1k-a3x9qz-1" \
Response ​
This endpoint returns 204 No Content with an empty body on success. It returns 404 if the handle isn't owned by the caller's workspace, and 400 if the deletion fails.
List incoming grants ​
Retrieves a list of grants that target the caller's workspace. The list view is lightweight. Each source_environments entry carries a has_assets boolean instead of the full asset list. Use the Get an incoming grant endpoint to retrieve the full asset list for a grant.
shell
GET /api/cross_workspace/incoming_grants
Query parameters ​
NameTypeDescription
page[number]integer
optional
page[size]integer
optional
Sample request ​
This request retrieves the grants that target your workspace.
shell
curl  -g -X GET "https://app.workato.com/api/cross_workspace/incoming_grants?page[number]=1&page[size]=100" \
Response ​
json
    "data": [
            "source_workspace": { "id": 8842, "name": "Acme Global" },
            "source_environments": [
                { "id": 123, "type": "prod", "has_assets": true }
    "total": 3,
Get an incoming grant ​
Retrieves a single grant that targets the caller's workspace. The single-grant view lists the shared assets for each source environment, including their access_levels.
shell
GET /api/cross_workspace/incoming_grants/:handle
URL parameters ​
NameTypeDescription
handlestring
required
The grant's handle.
Sample request ​
This request retrieves the incoming grant with the handle cwsgr-2f8h1k-a3x9qz-1.
shell
curl  -X GET "https://app.workato.com/api/cross_workspace/incoming_grants/cwsgr-2f8h1k-a3x9qz-1" \
Response ​
json
    "data": {
                "id": 123,
                "type": "prod",
                "assets": [
                    { "id": "48213", "name": "orders", "type": "Topic", "access_levels": ["read"] }
A handle that doesn't target the caller's workspace returns 404.
List source environments ​
Retrieves the caller workspace's environments that can act as a grant source.
shell
GET /api/cross_workspace/source_environments
Sample request ​
This request retrieves the environments that can act as a grant source.
shell
curl  -X GET "https://app.workato.com/api/cross_workspace/source_environments" \
Response ​
json
    "data": [
        { "id": 123, "type": "prod", "name": "Acme Global (prod)" },
        { "id": 124, "type": "test", "name": "Acme Global (test)" }
List target environments ​
Retrieves the sibling environments a given source environment can grant to. Targets are in the same Automation HQ organization and the same data center, and share the same environment type as the source.
shell
GET /api/cross_workspace/target_environments
Query parameters ​
NameTypeDescription
source_environment_idinteger
required
Sample request ​
This request retrieves the environments grantable from source environment 123.
shell
curl  -X GET "https://app.workato.com/api/cross_workspace/target_environments?source_environment_id=123" \
Response ​
json
    "data": [
This endpoint returns 400 if source_environment_id is omitted, and 404 if it doesn't belong to the caller's workspace.
