Developer API - Environment management ​
The following endpoints enable you to manage and secure your environments by providing tools for working with external secrets managers and monitoring user activities through activity audit log records. You can also create, retrieve, update, and delete tags within your workspace.
Rate limits ​
Environment management resources have the following rate limits:
TypeResourceQuota
AllAll Environment management endpoints60 requests per minute
Quick reference ​
TypeResourceDescription
POST/api/secrets_management/clear_cacheClears the secrets management cache.
GET/api/activity_logsRetrieves activity audit log records.
GET/api/tagsRetrieves a list of tags.
POST/api/tagsCreates a tag.
PUT/api/tags/:handleUpdates a tag.
DELETE/api/tags/:handleDeletes a tag.
Secrets cache behavior ​
Workato caches credentials retrieved from your external secrets manager for 60 minutes. During this period, recipes continue to use the cached value, even if you update or rotate the secret.
After the cache expires, the next recipe execution retrieves the latest value from your external secrets manager. You can call the Clear secrets management cache endpoint to apply changes immediately. This forces Workato to fetch the latest credentials without requiring you to disconnect and reconnect the connection.
Clear secrets management cache ​
Clears the secrets management cache to retrieve the latest available credentials from an external secrets manager. You don't need to disconnect and reconnect the connection for the refreshed credentials to take effect.
For example, when you update a secret in your external secrets manager, you can send a request to the Workato API simultaneously to clear the secrets management cache. This ensures that Workato retrieves the latest secret when required. This allows you to programmatically sync secrets with Workato every time they're changed as part of the secrets rotation process.
The request doesn't require a body.
POST https://YOUR_DATA_CENTER/api/secrets_management/clear_cache
Sample request ​
shell
curl  -X POST "https://YOUR_DATA_CENTER/api/secrets_management/clear_cache" \
      -H "Authorization: Bearer <api_token>"
Sample response ​
json
  "success": true
Get activity audit log ​
Retrieves detailed information on activities within a specific environment. You can use query parameters to filter the activity audit log by resource types, such as recipes and connections, or event types, such as creating or deleting recipes.
For a complete list of supported resource and event types, refer to the Activity audit log API reference.
GET https://YOUR_DATA_CENTER/api/activity_logs
The response includes two primary elements:
ElementDescription
dataAn array of objects, each representing a log entry.
totalThe total number of log entries returned.
Each log entry in the data array contains the event's unique identifier, timestamp, and type, as well as the following objects:
ObjectDescription
workspaceThis object includes the workspace ID, name, email, and environment.
In the Development environment, workspace.name corresponds to the workspace name.
In the Test and Production environments, workspace.name is Environment Test or Environment Production, respectively.
userThis object includes the user ID, name, and email.
detailsThis object provides additional information about the request. The request object contains the IP address and user agent. The activity field describes the specific action performed.
resourceThis object describes the resource involved, including its ID, name, type, email, and email_confirmed_at timestamp if applicable.
CREATE SEPARATE API CLIENTS FOR EACH ENVIRONMENT ACTIVITY LOGS
To obtain logs from different environments, create separate API clients for each environment and combine the data as required for your use case.
The following environments can appear in your response, depending on the API client associated with your environment:
  • dev (Development)
  • sandbox (Sandbox)
  • test (Test)
  • stage (Staging)
  • uat (User Acceptance Testing)
  • preprod (Pre-Production)
  • prod (Production)
Query parameters ​
NameTypeDescription
page[after]integer
optional
Specify the starting point for the next set of results based on the last result of the current page.
page[size]integer
optional
Specify the number of results per page. The default and maximum number of records is 100.
fromstring
optional
Specify the start of the time range for which to retrieve audit logs. Provide in ISO 8601 format (YYYY-MM-DDTHH:mm:ss.SSSZ).
tostring
optional
Specify the end of the time range for which to retrieve audit logs. Provide in ISO 8601 format (YYYY-MM-DDTHH:mm:ss.SSSZ).
users_ids[]array of integers
optional
Filter logs to include activities performed by specified user IDs.
include_resource_types[]array of strings
optional
Filter logs to include activities related to specified resource types.
exclude_resource_types[]array of strings
optional
Exclude activities related to specified resource types.
include_event_types[]array of strings
optional
Filter logs to include activities of specified event types.
exclude_event_types[]array of strings
optional
Exclude activities of the specified event types.
TIMEZONE
All data centers use the system timezone, Pacific Daylight Time (PDT). When you specify a timezone in the from and to query parameters, the system converts it to and displays it as PDT.
Sample requests ​
Request 1: Without query parameters ​
The following example request returns a list of all activities in the environment associated with the API client:
shell
curl  -X GET "https://YOUR_DATA_CENTER/api/activity_logs" \
Response 1: Without query parameters
json
  "data": [
      "id": 1234567,
      "timestamp": "2024-06-18 19:17:31 UTC",
      "event_type": "user_login",
      "workspace": {
        "id": 12345,
        "name": "Alex",
        "email": "[email protected]",
        "environment": "dev"
      "user": {
        "id": 12345,
        "name": "Alex",
      "details": {
        "request": {
          "ip_address": "60.160.90.91",
          "user_agent": "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/125.0.0.0 Safari/537.36"
        "activity": "password_login"
      "resource": {
        "id": 12345,
        "name": "Alex",
        "type": "Workspace",
        "email_confirmed_at": "2024-04-24 14:23:03 -0700"
  "total": 65
Request 2: Get the last three records ​
The following example request retrieves the three most recent activity log entries. This request returns activities for the environment associated with the API client:
shell
curl  -X GET "https://YOUR_DATA_CENTER/api/activity_logs?page%5Bsize%5D=:page_size_value" \
Response 2: Get the last three records
json
  "data": [
      "id": 3674006,
      "timestamp": "2024-06-26 15:56:07 UTC",
      "workspace": {
        "id": 12345,
        "name": "Alex",
      "user": {
        "id": 12345,
        "name": "Alex",
      "details": {
        "request": {
      "resource": {
        "id": 12345,
        "name": "Alex",
      "id": 3670909,
      "timestamp": "2024-06-25 16:38:11 UTC",
      "event_type": "recipe_created",
      "workspace": {
        "id": 12345,
        "name": "Alex",
      "user": {
        "id": 12345,
        "name": "Alex",
      "details": {
        "request": {
      "resource": {
        "id": 289287,
        "name": "My new recipe",
        "path": "Home/Demos",
        "type": "Flow",
        "folder_id": 46319
      "id": 3668492,
      "timestamp": "2024-06-24 15:52:23 UTC",
      "workspace": {
        "id": 12345,
        "name": "Alex",
      "user": {
        "id": 12345,
        "name": "Alex",
      "details": {
        "request": {
      "resource": {
        "id": 12345,
        "name": "Alex",
  "total": 65
Request 3: Get the activities of one day for two users ​
The following example request retrieves the activities of two users on June 30, 2024. This request returns activities for the environment associated with the API client:
shell
curl  -X GET "https://YOUR_DATA_CENTER/api/activity_logs?from=:from_value&to=:to_value&users_ids[]=:users_ids_value_1&users_ids[]=:users_ids_value_2" \
DATE AND TIME FORMAT
Ensure that the from and to query parameters use the YYYY-MM-DD format, where the month comes before the day. Using the YYYY-DD-MM format causes a 500 Server error.
Response 3: Get the activities of one day for two users
json
  "data": [
      "id": 3649152,
      "timestamp": "2024-06-30 23:09:51 UTC",
      "event_type": "connector_deleted",
      "workspace": {
        "id": 12345,
        "name": "Alex",
      "user": {
        "id": 12345,
        "name": "Alex",
      "details": {
        "request": {
      "resource": {
        "id": 7321,
        "name": "Calendly",
        "type": "CustomAdapter"
      "id": 3649149,
      "timestamp": "2024-06-30 23:07:33 UTC",
      "event_type": "connector_created",
      "workspace": {
        "id": 12345,
        "name": "Alex",
      "user": {
        "id": 12345,
        "name": "Alex",
      "details": {
        "request": {
      "resource": {
        "id": 7321,
        "name": "Calendly",
      "id": 3649129,
      "timestamp": "2024-06-30 22:34:36 UTC",
      "event_type": "user_logout",
      "workspace": {
        "id": 54321,
        "name": "Jie",
      "user": {
        "id": 54321,
        "name": "Jie",
      "details": {
        "request": {
          "ip_address": "192.0.2.1",
        "activity": "switch_team"
      "resource": {
        "id": 12345,
        "name": "Alex",
      "id": 3649127,
      "timestamp": "2024-06-30 22:32:43 UTC",
      "workspace": {
        "id": 54321,
        "name": "Jie",
      "user": {
        "id": 54321,
        "name": "Jie",
      "details": {
        "request": {
      "resource": {
        "id": 12345,
        "name": "Alex",
      "id": 3649124,
      "timestamp": "2024-06-30 22:32:16 UTC",
      "workspace": {
        "id": 54321,
        "name": "Jie",
      "user": {
        "id": 54321,
        "name": "Jie",
      "details": {
        "request": {
      "resource": {
        "id": 12345,
        "name": "Alex",
      "id": 3649123,
      "timestamp": "2024-06-30 22:32:00 UTC",
      "workspace": {
        "id": 54321,
        "name": "Jie",
      "user": {
        "id": 54321,
        "name": "Jie",
      "details": {
        "request": {
      "resource": {
        "id": 12345,
        "name": "Alex",
  "total": 6
Request 4: Include activities with specific resource_types and event_types ​
The following example request includes activities with the resource_type ApiPrivilegeGroup and event_type api_privilege_group_updated. This request returns activities for the environment associated with the API client:
shell
curl  -X GET "https://YOUR_DATA_CENTER/api/activity_logs?include_resource_types[]=ApiPrivilegeGroup&include_event_types[]=api_privilege_group_updated" \
Response 4: Include activities with specific resource_types and event_types
json
  "data": [
      "id": 3661175,
      "timestamp": "2024-06-18 17:38:33 UTC",
      "event_type": "api_privilege_group_updated",
      "workspace": {
        "id": 12345,
        "name": "Alex",
      "user": {
        "id": 12345,
        "name": "Alex",
      "details": {
        "request": {
      "resource": {
        "id": 40327,
        "name": "Recipe Operator",
        "type": "ApiPrivilegeGroup"
      "id": 3644097,
      "timestamp": "2024-06-04 21:37:12 UTC",
      "workspace": {
        "id": 12345,
        "name": "Alex",
      "user": {
        "id": 12345,
        "name": "Alex",
      "details": {
        "request": {
      "resource": {
        "id": 40327,
      "id": 3643744,
      "timestamp": "2024-06-04 16:24:44 UTC",
      "workspace": {
        "id": 12345,
        "name": "Alex",
      "user": {
        "id": 12345,
        "name": "Alex",
      "details": {
        "request": {
      "resource": {
        "id": 40327,
  "total": 3
Request 5: Exclude activities with specific resource_types and event_types ​
The following example request excludes activities with the resource_type User and event_type user_logout. This request returns activities for the environment associated with the API client:
shell
curl  -X GET "https://YOUR_DATA_CENTER/api/activity_logs?exclude_resource_types[]=User&exclude_event_types[]=user_logout" \
Response 5: Exclude activities with specific resource_types and event_types
json
  "data": [
      "id": 3670909,
      "workspace": {
        "id": 12345,
        "name": "Alex",
      "user": {
        "id": 12345,
        "name": "Alex",
      "details": {
        "request": {
      "resource": {
        "id": 289287,
        "type": "Flow",
        "folder_id": 46319
      "id": 3665078,
      "timestamp": "2024-06-20 20:00:36 UTC",
      "event_type": "connection_updated",
      "workspace": {
        "id": 12345,
        "name": "Alex",
      "user": {
        "id": 12345,
        "name": "Alex",
      "details": {
        "request": {
      "resource": {
        "id": 66196,
        "name": "My RecipeOps by Workato account",
        "type": "SharedAccount",
        "provider": "workato_app",
        "folder_id": 46319,
        "authorized": true
  "total": 42
Request 6: Get activities with a non-existent event type or user ID ​
The following example request attempts to retrieve the activities of a non-existent event type and user ID. Filtering activities by a non-existent event type or user ID results in an empty array:
shell
curl  -X GET "https://YOUR_DATA_CENTER/api/activity_logs?users_ids[]=:users_ids_value&include_event_types[]=nonexistent_event_type" \
Response 6: Get activities with a non-existent event type or user ID
json
  "data": [],
  "total": 0
List tags ​
Retrieves a list of tags in your workspace.
GET https://YOUR_DATA_CENTER/api/tags
MANAGE TAGS PROGRAMMATICALLY
Use the Manage tag assignments (POST /api/tags_assignments) endpoint to apply or remove asset tags.
Query parameters ​
NameTypeDescription
pagenumber
optional
The page number of the tags to retrieve. Defaults to 1.
per_pagenumber
optional
The number of tags to return in a single page. Defaults to 100. Maximum value is 100.
q[title_or_description_cont]string
optional
Filters results to include tags where the title or description contains the specified string.
Example: ...?q[title_or_description_cont]=hr
q[handle_in]array of strings
optional
Filters results to include only tags with handles that match the specified values. Each handle must be provided as a separate parameter instance.
Example: ...?q[handle_in][]=tag-APfXzndL-4whAmJ&q[handle_in][]=tag-APfWgxnc-Ggakzt
q[author_id_eq]number
optional
Filters results to include only tags created by the specified author (user ID).
Example: ...?q[author_id_eq]=30482
q[recipe_id_eq]number
optional
Filters results to include only tags associated with the specified recipe ID.
Example: ...?q[recipe_id_eq]=54525313
q[connection_id_eq]number
optional
Filters results to include only tags associated with the specified connection ID.
Example: ...?q[connection_id_eq]=1571346
q[only_assigned]boolean
optional
Filters results to include only tags that are assigned to an asset.
Example: ...?q[only_assigned]=true
sort_bystring
optional
Specifies the field to sort the response by. Accepts title, assignment_count, updated_at, or last_assigned_at.
Example: ...?sort_by=assignment_count
sort_directionstring
optional
Specifies the sort order for the response. Accepts asc or desc.
Example: ...?sort_direction=asc
includes[]array of strings
optional
Specifies additional fields to include in the response. Accepts assignment_count and author.
Example: ...?includes[]=author
Sample request ​
This request retrieves a list of tags and uses the includes[] query parameter to return both the author (the user who created the tag) and the number of times the tag has been assigned to an asset.
shell
curl  -X GET "https://YOUR_DATA_CENTER/api/tags?includes[]=author&includes[]=assignment_count" \
Response ​
json
  "data": {
    "tags": [
        "handle": "tag-ANgdXgTF-bANz3H",
        "title": "Accounting",
        "description": "Accounting tag",
        "color": "orange",
        "created_at": "2024-08-29T14:09:13-07:00",
        "updated_at": "2024-08-29T14:09:13-07:00",
        "author": {
            "id": 12345,
            "name": "Charlie",
            "avatar_url": ""
        "assignment_count": 6
        "handle": "tag-ANgef8oT-TgTeFY",
        "title": "Business development",
        "description": "Business development tag",
        "color": "green",
        "created_at": "2024-08-29T15:20:44-07:00",
        "updated_at": "2024-08-29T15:20:44-07:00",
        "author": {
            "id": 30482,
            "name": "Jie",
            "avatar_url": ""
        "assignment_count": 3
        "handle": "tag-ANgefFcG-RRkGKc",
        "title": "Finance",
        "description": "Finance tag",
        "color": "gold",
        "created_at": "2024-08-29T15:20:57-07:00",
        "updated_at": "2024-08-29T15:20:57-07:00",
        "author": {
            "id": 73913,
            "name": "Alex",
            "avatar_url": ""
        "assignment_count": 4
Create a tag ​
Creates a new tag in your workspace.
POST https://YOUR_DATA_CENTER/api/tags
Payload ​
NameTypeDescription
titlestring
required
The title of the tag. Maximum of 30 characters.
descriptionstring
optional
The description of the tag. Maximum of 150 characters.
colorstring
optional
The color of the tag. Accepted values include blue, violet, green, red, orange, gold, indigo, brown, teal, plum, slate, and neutral. If this field is not specified, Workato assigns the tag a random color.
Sample request ​
shell
curl  -X POST "https://YOUR_DATA_CENTER/api/tags" \
      -H "Authorization: Bearer <api_token>" \
      -d '{
            "title": ":title",
            "description": ":description",
            "color": ":color"
Response ​
json
  "data": {
    "handle": "tag-ANrzJTFF-wczhaW",
    "title": "HR",
    "description": "HR tag",
    "color": "green"
Update a tag ​
Updates an existing tag in your workspace.
PUT https://YOUR_DATA_CENTER/api/tags/:handle
URL parameters ​
NameTypeDescription
handlestring
required
The handle of the tag to update.
Payload ​
NameTypeDescription
titlestring
required
The updated tag title. Maximum of 30 characters.
descriptionstring
optional
The updated tag description. Maximum of 150 characters.
colorstring
optional
The updated tag color. Accepted values include blue, violet, green, red, orange, gold, indigo, brown, teal, plum, slate, and neutral.
Sample request ​
shell
curl  -X PUT "https://YOUR_DATA_CENTER/api/tags/:handle" \
      -d '{
            "title": ":title",
            "color": ":color"
Response ​
json
  "data": {
    "title": "Updated tag name",
    "description": "Updated the tag name",
    "color": "red"
Delete a tag ​
Deletes an existing tag in your workspace.
DELETE https://YOUR_DATA_CENTER/api/tags/:handle
URL parameters ​
NameTypeDescription
handlestring
required
The handle of the tag to delete.
Sample request ​
shell
curl  -X DELETE "https://YOUR_DATA_CENTER/api/tags/:handle" \
Response ​
If the request returns a 200 OK status code, the tag was successfully deleted. No content is returned in the response body.
