On-premise API
Workato API allows you to work with on-prem groups and on-prem agents through the API.
Rate limits
On-prem resources have the following rate limits:
| Type | Resource | Limit |
| All | All On-prem endpoints | 60 requests per minute |
Quick reference
| GET | /api/on_prem_groups | List on-prem groups. |
| POST | /api/on_prem_groups | Create on-prem group. |
| GET | /api/on_prem_groups/:id | Get on-prem group details. |
| PUT | /api/on_prem_groups/:id | Update on-prem group. |
| DELETE | /api/on_prem_groups/:id | Delete an on-prem group. |
| GET | /api/on_prem_groups/:id/status | Get on-prem group status. |
| GET | /api/on_prem_agents | List on-prem agents. |
| POST | /api/on_prem_agents | Create on-prem agent. |
| GET | /api/on_prem_agents/:id | Get on-prem agent details. |
| PUT | /api/on_prem_agents/:id | Update on-prem agent. |
| DELETE | /api/on_prem_agents/:id | Delete on-prem agents. |
| GET | /api/on_prem_agents/:id/status | Get on-prem agent status. |
| GET | /api/on_prem_agents/search | Search for on-prem agent. |
| GET | /api/on_prem_agents/:id/activation_code | Get on-prem agent activation code. |
List on-prem groups
List all on-prem groups in your workspace.
bash
GET https://YOUR_DATA_CENTER/api/on_prem_groupsSample request
shell
curl -X GET 'https://YOUR_DATA_CENTER/api/on_prem_groups' \
-H 'Authorization: Bearer <api_token>' \Response
json
"id": 16803,
"name": "CRM server",
"created_at": "2017-09-21T01:51:45.954-07:00",
"in_use": true,
"use_managed_connection": true,
"config_version": 9,
"logs_enabled": false,
"whitelisted_ips": [
"198.51.100.10",
"192.0.2.0/24"
]Create on-prem group
Create an on-prem group.
bash
POST https://YOUR_DATA_CENTER/api/on_prem_groupsPayload
| Name | Type | Description |
| name | string required | The on-prem group's name. |
| use_managed_connection | boolean optional | Set to true to configure the on-prem group using a cloud profile or false to configure each agent manually using a config.yml file. Defaults to false if not specified. |
| settings_attributes[whitelisted_ips] | array of strings optional | Defines IPs to whitelist for the on-prem group. |
Sample request
shell
curl -X POST 'https://YOUR_DATA_CENTER/api/on_prem_groups' \
-d '{
"name": ":name",
"use_managed_connection": :true_or_false,
"settings_attributes": {
":whitelisted_ip_1",
":whitelisted_ip_2"
}'Response
json
"id": 16803,
"in_use": false,
"config_version": null,
"198.51.100.10",
"192.0.2.0/24"
]Get on-prem group details
Get details about an on-prem group.
bash
GET https://YOUR_DATA_CENTER/api/on_prem_groups/:idURL parameters
| id | integer required | The ID of the on-prem group to retrieve. |
Sample request
shell
curl -X GET 'https://YOUR_DATA_CENTER/api/on_prem_groups/:id' \
json
"id": 16803,
"in_use": false,
"use_managed_connection": false,
"198.51.100.10",
"192.0.2.0/24"
]Update on-prem group
Update an on-prem group.
bash
PUT https://YOUR_DATA_CENTER/api/on_prem_groups/:idURL parameters
| id | integer required | The on-prem group's ID. |
Payload
| name | string optional | The on-prem group's name. |
Sample request
shell
curl -X PUT 'https://YOUR_DATA_CENTER/api/on_prem_groups/:id' \
-d '{
"name": ":name",
":whitelisted_ip_2"
}'Response
json
"id": 16803,
"in_use": false,
"198.51.100.10",
"192.0.2.0/24"
]Delete on-prem group
Delete an on-prem group and the on-prem agents it contains.
bash
DELETE https://YOUR_DATA_CENTER/api/on_prem_groups/:idURL parameters
Sample request
shell
curl -X DELETE 'https://YOUR_DATA_CENTER/api/on_prem_groups/:id' \
json
"success": true
}Get on-prem group status
Get the status of an on-prem group.
bash
GET https://YOUR_DATA_CENTER/api/on_prem_groups/:id/statusURL parameters
Sample request
shell
curl -X GET 'https://YOUR_DATA_CENTER/api/on_prem_groups/:id/status' \
json
"agent_count": 4,
"active_agent_count": 3,
"profiles": [
"name": "CRM-Oracle",
"provider": "oracle",
"type": "Database",
"connections": [
"id": 440724,
"name": "Oracle CRM DB"
}List on-prem agents
List all on-prem agents in your workspace.
bash
GET https://YOUR_DATA_CENTER/api/on_prem_agentsSample request
shell
curl -X GET 'https://YOUR_DATA_CENTER/api/on_prem_agents' \
json
"id": 12233,
"on_prem_group_id": 16803,
"name": "primary agent",
"cn": "134fd7acd89cf5b8b96deea4870d413d:12233",
"os": "windows",
"installation_method": null,
"awaiting_setup": false,
"enabled": true,
"last_seen_version": "25.0",
"created_at": "2024-12-10T13:20:03.330-08:00",
"updated_at": "2025-05-12T13:03:23.754-07:00",
"state": "connected",
"activated": true
]Create on-prem agent
Create an on-prem agent.
bash
POST https://YOUR_DATA_CENTER/api/on_prem_agentsPayload
| name | string required | The on-prem agent's name. |
| on_prem_group_id | integer required | The on-prem group's ID. You can retrieve group IDs from the List on-prem groups endpoint's response. |
| os | string optional | The server's operating system. |
| awaiting_setup | boolean optional | Set to true to create the agent in the awaiting_setup state. Set to false to skip agent setup and get its status right away. Defaults to true if not specified. |
| enabled | boolean optional | Set to true to enable the agent or false to disable it. |
Sample request
shell
curl -X POST 'https://YOUR_DATA_CENTER/api/on_prem_agents' \
-d '{
"name": ":name",
"on_prem_group_id": :on_prem_group_id_value,
"os": ":os",
"awaiting_setup": :true_or_false
}'Response
json
"id": 12233,
"on_prem_group_id": 50,
"name": "US-west-1",
"os": "windows",
"enabled": true,
"last_seen_version": null,
"created_at": "2025-06-24T12:37:49.824-07:00",
"updated_at": "2025-06-24T12:37:49.886-07:00",
"activated": false
]Get on-prem agent details
Get the details of an on-prem agent.
bash
GET https://YOUR_DATA_CENTER/api/on_prem_agents/:idURL parameters
| id | integer required | The on-prem agent's ID. |
Sample request
shell
curl -X GET 'https://YOUR_DATA_CENTER/api/on_prem_agents/:id' \
json
"id": 12233,
"os": "windows",
"awaiting_setup": true,
"enabled": true,
"state": "awaiting_setup",
"activated": false
]Update on-prem agent
Update an on-prem agent.
bash
PUT https://YOUR_DATA_CENTER/api/on_prem_agents/:idURL parameters
Payload
| name | string optional | The on-prem agent's name. |
| on_prem_group_id | integer optional | The on-prem group's ID. You can retrieve group IDs from the List on-prem groups endpoint's response. |
Sample request
shell
curl -X PUT 'https://YOUR_DATA_CENTER/api/on_prem_agents/:id' \
-d '{
"name": ":name"
}'Response
json
"id": 49026,
"on_prem_group_id": 32109,
"cn": "1ee944db3b24d7c19dfe4685c49b77a4:49026",
"os": "windows",
"enabled": true,
"last_seen_version": "27.0",
"created_at": "2025-03-27T08:18:49.641-07:00",
"updated_at": "2025-05-12T13:26:36.731-07:00",
"activated": true
]Delete on-prem agent
Delete an on-prem agent.
bash
DELETE https://YOUR_DATA_CENTER/api/on_prem_agents/:idURL parameters
Sample request
shell
curl -X DELETE 'https://YOUR_DATA_CENTER/api/on_prem_agents/:id' \
json
"success": true
}Get on-prem agent status
Get the status of an on-prem agent.
bash
GET https://YOUR_DATA_CENTER/api/on_prem_agents/:id/statusURL parameters
Sample request
shell
curl -X GET 'https://YOUR_DATA_CENTER/api/on_prem_agents/:id/status' \
json
"active": true
}Search for on-prem agent by common name
Search on-prem agents by their common name.
bash
GET https://YOUR_DATA_CENTER/api/on_prem_agents/searchURL parameters
| cn | string optional | The common name of the on-prem agent to retrieve. Omit this parameter to return all agents. |
Sample request
shell
curl -X GET 'https://YOUR_DATA_CENTER/api/on_prem_agents/search' \
-d '{
}'Response
json
"id": 12233,
"os": "windows",
"enabled": true
]Get on-prem agent activation code
Get an activation code for an on-prem agent.
bash
GET https://YOUR_DATA_CENTER/api/on_prem_agents/:id/activation_codeURL parameters
Sample request
shell
curl -X GET 'https://YOUR_DATA_CENTER/api/on_prem_agents/:id/activation_code' \
json
"code": "eyJ0eXAiOiJKV1QiLCJhbGciOiJSUzI1NiJ9.eyJzdWIiOiJiMjY3MTA4NTU5NDBmMGFjYTVmNDYyMTFhNWYxMmJiNzo2MDg3MCIsImlhdCI6MTc0ODcyNTU5OSwiZXhwIjoxNzQ4NzI5MTk5LCJhZ2VudCI6NjA4NzAsImd3Ijoic2czLndvcmthdG8uY29tfHNnNC53b3JrYXRvLmNvbSJ9.JCcQ0NCetvIjP9xJJ1BIUAxmE9ImuNvtUJLNIazICiQg61RlSz2YJHywhbSXvakjjB77L7ZPydo43Rs_iiWiWRr5atk8iHvZlnfAKL_338-nFxmSkN-Ms7sL-fguNdQaO-DgkkZubAJ-qP8a34VKJ6QYA3c3SaixoNfnukKan0mUySTz7wQsVxU4C0Ff0R42AGO9CjKxYRobeBr_QgLJm6PtSUN5J6JkWGpyg9jTHJEpsFPDLBzJ0u7O7HkDP_onF4wdrraJ7_5BSn04ZllXw6oIwTbMWq1ncqhYHs0ZXNnv3efXF4L0tzgSkekdz-YasqojNSo0wzfpV0W_3vq_Mg"
]Last updated:
