# New component event trigger
The New component event trigger runs when a Run recipe action is invoked in the Workflow apps portal. Use this trigger in combination with the Return data to component action to send data back to a page component in a Workflow app.
| Input parameters | Use input parameters to receive data from the Workflow apps page for use in your recipe. For example, you can use page data to search for relevant records in a third-party app. |
| Output schema | Specify output fields to send data obtained in this recipe back to your Workflow apps page. |
| Context | The context object contains information about the Workflow apps user using the page, including app-user details and group membership. |
| Workflow apps user | This object is nested within the Context object and contains the following available attributes:
| Parameters | The parameters object is nested within the Context object and contains input parameters defined in the trigger. This object is empty if you haven't defined any input parameters. |
Last updated: 8/28/2025, 10:12:07 PM
