# XML tools by Workato – Parse XML document action
The Parse XML document action extracts data from an XML document and converts it into datapills for use in subsequent recipe steps.
Input field Description
XML type Select the level of detail to parse from the XML document. Workato determines the data type of each datapill based on the XML content. Choose Simple XML without attributes to generate a streamlined datatree that includes only the default XML syntax and the type attribute, ignoring all other attributes. Choose Full XML with attributes to include all attributes in the output. Each XML tag appears as an Array datapill, with values stored under a Content datapill. Refer to the Output section for more information.
Sample document Provide a sample XML document that matches the expected format of the XML data. Workato uses this sample to generate the output datatree.
Encoding of the file content Specify the encoding format for the XML file. If left blank, Workato defaults to UTF-8.
Document Provide the XML data to parse. Workato extracts values based on the selected XML type and generates datapills for use in subsequent recipe steps.
The parsed XML data appears as a structured datatree. The structure depends on the XML type selected.
For example, given the following XML input:
<list>
  <Contact>
      <Name type="C">
        <First>Donna</First>
        <Last>Noble</Last>
      </Name>
  </Contact>
  <Contact>
      <Name type="C">
        <First>Rose</First>
        <Last>Tyler</Last>
      </Name>
  </Contact>
</list>
The resulting datatree varies based on the XML type:
SIMPLE XML WITHOUT ATTRIBUTES
. List
  └── Contact
      ├── Name
      |   ├── Type (C)
      |   ├── First (Rose)
      |   └── Last (Tyler)
      ├── List size
      └── List index
FULL XML WITH ATTRIBUTES
. List
  ├── Contact
  |     ├── Name
  |     |   ├── Type (C)
  |     |   ├── First
  |     |   |     ├── Content (Rose)
  |     |   |     ├── List size
  |     |   |     └── List index
  |     |   ├── Last
  |     |   |     ├── Content (Tyler)
  |     |   |     ├── List size
  |     |   |     └── List index
  |     |   ├── List size
  |     |   └── List index
  |     ├── List size
  |     └── List index
  ├── List size
  └── List index
# Integrate XML into recipes
The Parse XML document action extracts structured data from XML, but some workflows require additional setup to ingest XML from external systems. Workato provides multiple ways to receive and process XML beyond parsing.
Last updated: 1/21/2026, 10:04:53 PM
