# MCP server registry
MCP (Model Context Protocol) servers lets LLMs interact with external tools and services. The Workato MCP server registry provides a trusted framework for integrating AI-enabled tooling into development, automation, and operational workflows, and security and compliance controls. The MCP server registry transforms static API models into active agents capable of executing real work.
Many vendor-provided MCP servers are essentially API wrappers that expose a fixed set of actions with no ability to add business logic, enforce custom checks, or adapt tools to your workflows. Workato's MCP server registry takes a different approach. The registry provides a collection of prebuilt MCP servers you can deploy in minutes and fully customize to match your specific use cases. You can add, modify, or remove tools, and build in logic like validation steps, conditional routing, or approval flows using skill recipes. Access is controlled through user provisioning and rate limits, and each agent action is tied to an authenticated user for full traceability.
# Use a prebuilt MCP server
Prebuilt MCP servers must be added in Workato and in your MCP client, such as Cursor, ChatGPT, or Claude.
# Install a prebuilt MCP server in Workato
Complete the following steps to install a prebuilt MCP server in your Workato project:
Go to AI Hub > MCP servers.
Click + Create MCP server.
Go to the Start with pre-built MCP Servers using your connected apps section and select the template you plan to use.
Start with pre-built MCP Servers using your connected appsGo to the Start with pre-built MCP Servers using your connected apps section
Click Use this server.
Use the Location drop-down menu to select a location for your MCP server.
Select the connection type you plan to use for the prebuilt MCP server.
Use the MCP server registry to find app-specific connection documentation.
# LLM-facing MCP server description
Prebuilt MCP servers include a default MCP server description with detailed information. This description is automatically shared with your LLM when you connect the MCP server. You can update the description for your specific use cases and to include any tool customization you perform.
# Edit LLM-facing MCP server description
Complete the following steps to edit the MCP server description shared with your LLM:
Select the MCP server where you plan to edit the LLM-facing MCP server description.
Go to the Description section and click the edit icon.
Update the description.
Update the LLM-facing descriptionUpdate the LLM-facing description
Click the save icon.
# Add a prebuilt MCP server to an AI model
Refer to AI model configuration for instructions on how to add and configure your MCP server in an AI model, such as Cursor, Claude, or ChatGPT.
# Manage MCP server tools
TOOLS MUST BE STARTED
# Add users to an MCP server
You can provision end users with access to your MCP server. Refer to Workato Identity for more information.
# Configure MCP server limits
You can add custom rate limits, usage quotas, and IP restrictions for your MCP server.
Rate limits control request frequency and prevent traffic bursts.
Refer to Configure MCP server limits for more information.
Last updated: 4/6/2026, 4:37:13 PM
