Custom OAuth profiles
Use the endpoints below to manage custom OAuth profiles programmatically.
Rate limits
Custom OAuth profile resources have the following rate limits:
TypeResourceQuota
AllAll Custom OAuth profiles endpoints60 requests per minute
Quick reference
TypeResourceDescription
GET/api/custom_oauth_profilesList Custom OAuth profiles.
GET/api/custom_oauth_profiles/:idGet a Custom OAuth profile by ID.
POST/api/custom_oauth_profilesCreate a Custom OAuth profile.
PUT/api/custom_oauth_profiles/:idUpdate a Custom OAuth profile.
DELETE/api/custom_oauth_profiles/:idDelete a Custom OAuth profile.
List custom OAuth profiles. Client secrets and tokens are never returned in the response.
GET https://YOUR_DATA_CENTER/api/custom_oauth_profiles
Query parameters
NameTypeDescription
pageintegerPage number. Defaults to 1.
per_pageintegerPage size. Defaults to 100 (maximum is 100).
Sample request
shell
curl  -X GET 'https://YOUR_DATA_CENTER/api/custom_oauth_profiles' \
Response
json
  "result": [
        "id": 321,
        "user_id": 123,
        "name": "Acme HubSpot OAuth app",
        "provider": "hubspot",
        "data": {
          "client_id": "example_client_id"
        "shared_accounts_count": 1,
        "oem_customers_count": 5,
        "created_at": "2023-01-15T11:50:32.986-07:00",
        "updated_at": "2023-01-15T11:50:32.986-07:00"
Get Custom OAuth profile by ID
Retrieves a custom OAuth profile by ID. Client secrets and tokens are never returned in the response.
GET https://YOUR_DATA_CENTER/api/custom_oauth_profiles/:id
Path parameters
NameTypeDescription
idinteger
required
ID of the Custom OAuth profile to retrieve
Sample request
shell
curl  -X GET 'https://YOUR_DATA_CENTER/api/custom_oauth_profiles/:id' \
Response
json
  "result": {
    "id": 321,
    "user_id": 123,
    "data": {
POST https://YOUR_DATA_CENTER/api/custom_oauth_profiles
Payload
NameTypeDescription
namestring
required
The name of the OAuth profile.
providerstring
required
The name of the app tied to this Custom OAuth profile.
data.client_idstring
required
The Client ID of the Custom OAuth App
data.client_secretstring
required
The Client secret of the Custom OAuth App
data.tokenstring
optional
Only required for Slack Apps. The token of the Custom OAuth App
Sample request
shell
curl  -X POST https://YOUR_DATA_CENTER/api/custom_oauth_profiles \
      -d '{
            "name": ":name",
            "provider": ":provider",
            "data": {
              "client_id": ":client_id",
              "client_secret": ":client_secret"
Response
json
  "result": {
    "id": 322,
    "user_id": 123,
    "name": "My new OAuth profile",
    "data": {
    "shared_accounts_count": 0,
    "oem_customers_count": 0,
PUT https://YOUR_DATA_CENTER/api/custom_oauth_profiles/:id
Path parameters
NameTypeDescription
idinteger
required
ID of the Custom OAuth profile to update
Payload
NameTypeDescription
namestring
required
providerstring
required
required
required
data.tokenstring
optional
Sample request
shell
curl  -X PUT https://YOUR_DATA_CENTER/api/custom_oauth_profiles/:id \
      -d '{
            "name": ":name",
            "data": {
Response
json
  "result": {
    "id": 322,
    "user_id": 123,
    "name": "My updated OAuth profile",
    "data": {
      "client_id": "updated_client_id"
DELETE https://YOUR_DATA_CENTER/api/custom_oauth_profiles/:id
Path Parameters
NameTypeDescription
idintegerID of the Custom OAuth profile to delete
Sample request
shell
curl  -X DELETE https://YOUR_DATA_CENTER/api/custom_oauth_profiles/:id \
Response
json
  "result": {
    "success": true
