Developer API - Role migration ​
Use the following endpoints to convert legacy roles into environment and project roles. Alternatively, you can use the in-app migration wizard.
RBAC 2.0 MIGRATION
These endpoints are deprecated after your workspace migrates to the new role-based access control model, since a migrated workspace has no remaining legacy roles to migrate. Refer to RBAC 2.0 migration - Developer and Embedded API changes for details.
Rate limits ​
The role migration resource has the following rate limit:
TypeResourceQuota
All All Role migration endpoints60 requests per minute
Quick reference ​
TypeResourceDescription
POST/api/roles_migration/system_rolesMigrate system roles.
POST/api/roles_migration/custom_roleMigrate a custom role.
Migrate system roles ​
Converts legacy system roles into environment and project roles. You can also use the in-app migration wizard to migrate system roles.
POST https://YOUR_DATA_CENTER/api/roles_migration/system_roles
Request body ​
NameTypeDescription
dry_runboolean
optional
Returns a JSON response without migrating roles when set to true. The default value is false.
Sample request ​
shell
curl -X POST 'https://YOUR_DATA_CENTER/api/roles_migration/system_roles' \
Response ​
json
  "data": {
    "environment_roles": [
        "name": "EnvironmentAdmin",
        "config": { /* Environment admin permissions */ }
        "name": "EnvironmentManager",
        "config": { /* Environment manager permissions */ }
        "name": "Member",
        "config": { /* Member permissions */ }
    "project_roles": [
        "name": "ProjectAdmin",
        "config": { /* Project admin permissions */ }
        "name": "AdvancedBuilder",
        "config": { /* Advanced builder permissions */ }
       "name": "ProjectOperator",
        "config": { /* Project operator permissions */ }
    "collaborators": [
        "user_id": 1,
        "email": "[email protected]",
        "name": "Kim",
        "roles": [
          { "environment": "dev", "name": "EnvironmentAdmin" },
          { "environment": "prod", "name": "EnvironmentManager" },
          { "environment": "test", "name": "Member" }
    "projects": [
        "id": 101,
        "name": "Dev Project",
        "collaborators": [
            "user_id": 1,
            "name": "Izumi",
            "project_role": "ProjectAdmin"
    "moderators": [
        "user_id": 201,
        "name": "Sasha",
        "environment_role": "EnvironmentAdmin",
Config objects
Config objects contain the permissions configured for a role. For example, the following is the Config object for the environment admin role:
json
"config": {
          "personalization": {"privileges": "all"},
          "topic": {"privileges": "all"},
          "lookup_table": {"privileges": "all"},
          "people_task": {"privileges": "all"},
          "manage_projects": {"privileges": "all"},
          "custom_adapter_sdk": {"privileges": "all"},
          "custom_adapter_use_in_recipes": {"privileges": "all"},
          "opa": {"privileges": "all"},
          "connection_opa_files": {"privileges": "all"},
          "connection_opa_cmd_scripts": {"privileges": "all"},
          "api_key": {"privileges": "all"},
          "service_console": {"privileges": "all"},
          "api_platform_dashboard": {"privileges": "all"},
          "api_platform_endpoints": {"privileges": "all"},
          "api_platform_clients": {"privileges": "all"},
          "api_platform_policies": {"privileges": "all"},
          "api_platform_settings": {"privileges": "all"},
          "apim_proxy_transformation": {"privileges": "all"},
          "workato_schema": {"privileges": "all"},
          "custom_oauth_key": {"privileges": "all"},
          "workato_template": {"privileges": "all"},
          "workbot": {"privileges": "all"},
          "enterprise_workbot": {"privileges": "all"},
          "group_recommendations": {"privileges": "all"},
          "job_history_search": {"privileges": "all"},
          "action_timeout": {"privileges": "all"},
          "data_masking": {"privileges": "all"},
          "identity_service_settings": {"privileges": ["read", "update"]},
          "identity_service_users_and_groups": {"privileges": ["read", "create", "update", "delete"]},
          "lcap_portal_settings": {"privileges": ["read", "update"]},
          "lcap_portal_user_groups": {"privileges": ["read", "create", "update", "delete"]},
          "lcap_public_pages": {"privileges": "all"},
          "lcap_app_functions": {"privileges": ["read", "create", "update", "delete"]},
          "lcap_page_actions": {"privileges": "all"},
          "lcap_custom_domains": {"privileges": "all"},
          "lcap_insights": {"privileges": "all"},
          "file_storage": {"privileges": "all"},
          "account_property": {"privileges": "all"},
          "data_mapper": {"privileges": "all"},
          "audit_log_replication": {"privileges": "all"},
          "apim_log_replication": {"privileges": "all"},
          "activity_logs": {"privileges": "all"},
          "saml": {"privileges": "all"},
          "team": {"privileges": "all"},
          "package": {"privileges": "all"},
          "custom_roles": {"privileges": "all"},
          "api_clients": {"privileges": "all"},
          "oem_vendor": {"privileges": "all"},
          "workspace_settings": {"privileges": "all", "enable_for": "non_oem"},
          "environment_settings": {"privileges": "all", "enable_for": "non_oem"},
          "oem_admin_settings": {"privileges": "all", "enable_for": "org_admin_with_settings"},
          "oem_customer_settings": {"privileges": "all", "enable_for": "org_customer_with_settings"},
          "logging_service": {"privileges": "all"},
          "general_provisioning": {"privileges": "all"},
          "account_deletion": {"privileges": "all"},
          "disable_two_fa": {"privileges": "all"},
          "configurable_data_retention": {"privileges": "all"},
          "extended_60_days_data_retention": {"privileges": "all"},
          "extended_data_retention": {"privileges": "all"},
          "cmk_management": {"privileges": "all"},
          "external_secret_sources": {"privileges": "all"},
          "federation_management": {"privileges": "all", "enable_for": "federation"},
          "scim": {"privileges": "all"},
          "oem_ac_customers": {"privileges": "all", "enable_for": "oem_admin"},
          "oem_ac_automations": {"privileges": "all", "enable_for": "oem_admin"},
          "oem_ac_analytics": {"privileges": "all", "enable_for": "oem_admin"},
          "usage_insights": {"privileges": ["read", "create", "update", "delete"]},
          "usage_dashboard": {"privileges": ["read"]},
          "cbp_usage_dashboard": {"privileges": ["read"]}
Migrate a custom role ​
Converts legacy custom roles into environment and project roles. Alternatively, you can use the in-app migration wizard to migrate custom roles.
POST https://YOUR_DATA_CENTER/api/roles_migration/custom_role
Request body ​
NameTypeDescription
privilege_group_idinteger
required
The ID of the role to convert.
environment_roleobject
required
Defines the environment role to create.
environment_role[name]string
required
The name of the new environment role.
environment_role[additional_permissions]object
optional
Specifies additional permissions for the new environment role.
project_roleobject
required
Defines the project role to create.
project_role[name]string
required
The name of the new project role.
project_role[additional_permissions]object
optional
Specifies additional permissions for the new project role.
dry_runboolean
optional
Sample request ​
shell
curl -X POST 'https://YOUR_DATA_CENTER/api/roles_migration/custom_role' \
  -H "Authorization: Bearer <api_token>" \
  -d '{
        "privilege_group_id": :privilege_group_id_value,
        "environment_role": {
          "name": ":environment_role_name",
          "additional_permissions": :environment_additional_permissions
        "project_role": {
          "name": ":project_role_name",
          "additional_permissions": :project_additional_permissions
Response ​
json
  "data": {
        "name": "New Environment role",
        "config": {
          "lookup_table": {
            "privileges": ["create", "access_control"]
    "project_roles": [
        "name": "New project role",
        "config": {
          "recipe": {
          "project_administration": {
            "privileges": ["access_control"]
    "collaborators": [
        "user_id": 1,
        "name": "Yuri",
        "roles": [
          { "environment": "dev", "name": "New Environment role" },
          { "environment": "prod", "name": "New Environment role" },
          { "environment": "test", "name": "New Environment role" }
    "projects": [
        "id": 1,
        "collaborators": [
            "user_id": 1,
            "name": "Hao",
            "project_role": "New project role"
    "moderators": [
        "user_id": 1,
        "name": "Lucian",
        "environment_role": "New Environment role",
