RBAC 2.0 migration - Developer and Embedded API changes
Workato is migrating workspaces to the new role-based access control model, which replaces legacy system roles (Admin, Analyst, Operator) with environment roles and project roles. This document lists the Developer API and Embedded API payload and response changes that take effect after a workspace completes this migration.
ACTION REQUIRED
After your workspace migrates, these endpoints no longer accept the role_name parameter or env_roles[role_type]: "privilege_group". Update integrations to use env_roles with role_type: "environment" before your workspace migrates to avoid disruptions.
Does this affect me?
This affects your integration if it uses any of the following with the Developer API or Embedded API:
- The
role_nameparameter to invite or update a collaborator env_roles[role_type]set toprivilege_group- Legacy role names, such as
Admin,Analyst, orOperator, that don't exist as custom environment roles in your workspace - The legacy roles endpoints (
/api/roles,/api/managed_users/:managed_user_id/roles) or the role migration endpoints (/api/roles_migration/*)
NOT YET MIGRATED
If your workspace hasn't been migrated yet, continue using the existing Workspace collaborators, Legacy roles, and Embedded API - Manage customers documentation. The changes on this page don't apply until your workspace completes migration. Contact your customer success manager or Workato Support for migration guidance.
Developer API changes
These changes affect collaborator and legacy role endpoints in the Developer API, used to manage collaborators and roles in your own workspace.
Invite a collaborator
After migration, the Invite a collaborator endpoint requires env_roles with role_type: "environment". It no longer accepts role_name or role_type: "privilege_group".
Legacy format (rejected after migration):
curl --location 'https://YOUR_DATA_CENTER/api/member_invitations' \
--data-raw '{
"name": ":name",
"email": ":email",
"env_roles": [
"environment_type": "dev",
"name": "Member",
"role_type": "privilege_group"
}'New format (required):
--data-raw '{
"name": ":name",
"email": ":email",
"env_roles": [
"name": "Member",
"role_type": "environment"
}'If you pass env_roles[role_type]: "privilege_group" for a role name that only exists as an environment role, the endpoint returns a 400 error:
"message": "Role Member not found. If this is an RBAC 2.0 environment role, pass it via env_roles with role_type: \"environment\"."
}If you pass a legacy role name, such as Admin, Analyst, or Operator, that no longer exists after migration, the endpoint returns a 400 error:
"message": "Legacy roles can't be created, edited or used after migration"
}Update collaborator roles
After migration, the Update collaborator roles endpoint no longer accepts role_type: "privilege_group". Pass env_roles with role_type: "environment" instead.
curl --location --request PUT 'https://YOUR_DATA_CENTER/api/members/:id' \
--data '{
"env_roles": [
"name": "Analyst",
--data '{
"env_roles": [
"name": "Member",
}'Legacy roles
The Legacy roles endpoints are deprecated after migration, since a migrated workspace no longer has legacy custom roles to list, copy, or update.
| Endpoint | Behavior after migration |
| GET /api/roles | Returns a 200 OK status with an empty response. |
| POST /api/roles/:id/copy | Returns a 400 error. |
| PUT /api/roles/:id | Returns a 400 error. |
| GET /api/members/:id/privileges | Returns environment-level privileges only. Use Get collaborator project privileges to retrieve project-level access. |
Use Environment roles and Project roles to manage roles instead.
Role migration
The Role migration endpoints are deprecated after migration, since a migrated workspace has no remaining legacy roles to migrate.
Embedded (OEM) API changes
These changes affect the same collaborator and legacy role endpoints in the Embedded API, scoped to managed_users and used to manage collaborators and roles in your customers' workspaces.
Invite a collaborator to a customer workspace
After migration, the Invite a collaborator to a customer workspace endpoint requires env_roles with role_type: "environment". It no longer accepts role_name or role_type: "privilege_group".
curl --location 'https://YOUR_DATA_CENTER/api/managed_users/:managed_user_id/member_invitations' \
--data-raw '{
"name": ":name",
"email": ":email",
"role_name": "Admin"
--data-raw '{
"name": ":name",
"email": ":email",
"env_roles": [
"name": "Environment manager",
}'Add a collaborator to a customer workspace
After migration, the Add collaborator to customer workspace endpoint requires env_roles with role_type: "environment". It no longer accepts role_name or role_type: "privilege_group".
curl --location 'https://YOUR_DATA_CENTER/api/managed_users/:managed_user_id/members' \
--data-raw '{
"name": ":name",
"role_name": "Admin",
"external_id": ":external_id"
--data-raw '{
"name": ":name",
"external_id": ":external_id",
"env_roles": [
}'Update a customer workspace collaborator
After migration, the Update customer workspace collaborator endpoint requires env_roles with role_type: "environment". It no longer accepts role_name or role_type: "privilege_group".
curl --location --request PUT 'https://YOUR_DATA_CENTER/api/managed_users/:managed_user_id/members/:member_id' \
--data '{
--data '{
"env_roles": [
"name": "Environment admin",
}'Legacy roles
The Embedded API - Legacy roles endpoints are deprecated after migration, since a migrated customer workspace no longer has legacy custom roles to list or copy.
| GET /api/managed_users/:managed_user_id/roles | Returns a 200 OK status with an empty response. |
| POST /api/managed_users/:managed_user_id/roles/:role_id/copy | Returns a 400 error. |
| GET /api/managed_users/:managed_user_id/members/:member_id/privileges | Returns environment-level privileges only. Use Get projects privileges from a customer workspace collaborator to retrieve project-level access. |
Use Embedded API - Environment roles and Embedded API - Project roles to manage roles instead.
