Role migration
Use the following endpoints to convert legacy roles into environment and project roles. Alternatively, you can use the in-app migration wizard.
Rate limits
The role migration resource has the following rate limit:
| Type | Resource | Limit |
| All | All Role migration endpoints | 60 requests per minute |
Quick reference
| POST | /api/roles_migration/system_roles | Migrate system roles. |
| POST | /api/roles_migration/custom_role | Migrate a custom role. |
Converts legacy system roles into environment and project roles. You can also use the in-app migration wizard to migrate system roles.
bash
POST https://YOUR_DATA_CENTER/api/roles_migration/system_rolesRequest body
| Name | Type | Description |
| dry_run | boolean optional | Returns a JSON response without migrating roles when set to true. The default value is false. |
Sample request
shell
curl -X POST 'https://YOUR_DATA_CENTER/api/roles_migration/system_roles' \
-H 'Authorization: Bearer <api_token>'Response
json
"data": {
"environment_roles": [
"name": "EnvironmentAdmin",
"config": { /* Environment admin permissions */ }
"name": "EnvironmentManager",
"config": { /* Environment manager permissions */ }
"name": "Member",
"config": { /* Member permissions */ }
"project_roles": [
"name": "ProjectAdmin",
"config": { /* Project admin permissions */ }
"name": "AdvancedBuilder",
"config": { /* Advanced builder permissions */ }
"name": "ProjectOperator",
"config": { /* Project operator permissions */ }
"collaborators": [
"user_id": 1,
"email": "[email protected]",
"name": "Kim",
"roles": [
{ "environment": "dev", "name": "EnvironmentAdmin" },
{ "environment": "prod", "name": "EnvironmentManager" },
{ "environment": "test", "name": "Member" }
"projects": [
"id": 101,
"name": "Dev Project",
"collaborators": [
"user_id": 1,
"name": "Izumi",
"project_role": "ProjectAdmin"
"moderators": [
"user_id": 201,
"name": "Sasha",
"environment_role": "EnvironmentAdmin",
}Config objects
Config objects contain the permissions configured for a role. For example, the following is the Config object for the environment admin role:
json
"config": {
"personalization": {"privileges": "all"},
"topic": {"privileges": "all"},
"lookup_table": {"privileges": "all"},
"people_task": {"privileges": "all"},
"manage_projects": {"privileges": "all"},
"custom_adapter_sdk": {"privileges": "all"},
"custom_adapter_use_in_recipes": {"privileges": "all"},
"opa": {"privileges": "all"},
"connection_opa_files": {"privileges": "all"},
"connection_opa_cmd_scripts": {"privileges": "all"},
"api_key": {"privileges": "all"},
"service_console": {"privileges": "all"},
"api_platform_dashboard": {"privileges": "all"},
"api_platform_endpoints": {"privileges": "all"},
"api_platform_clients": {"privileges": "all"},
"api_platform_policies": {"privileges": "all"},
"api_platform_settings": {"privileges": "all"},
"apim_proxy_transformation": {"privileges": "all"},
"workato_schema": {"privileges": "all"},
"custom_oauth_key": {"privileges": "all"},
"workato_template": {"privileges": "all"},
"workbot": {"privileges": "all"},
"enterprise_workbot": {"privileges": "all"},
"group_recommendations": {"privileges": "all"},
"job_history_search": {"privileges": "all"},
"action_timeout": {"privileges": "all"},
"data_masking": {"privileges": "all"},
"identity_service_settings": {"privileges": ["read", "update"]},
"identity_service_users_and_groups": {"privileges": ["read", "create", "update", "delete"]},
"lcap_portal_settings": {"privileges": ["read", "update"]},
"lcap_portal_user_groups": {"privileges": ["read", "create", "update", "delete"]},
"lcap_public_pages": {"privileges": "all"},
"lcap_app_functions": {"privileges": ["read", "create", "update", "delete"]},
"lcap_page_actions": {"privileges": "all"},
"lcap_custom_domains": {"privileges": "all"},
"lcap_insights": {"privileges": "all"},
"file_storage": {"privileges": "all"},
"account_property": {"privileges": "all"},
"data_mapper": {"privileges": "all"},
"audit_log_replication": {"privileges": "all"},
"apim_log_replication": {"privileges": "all"},
"activity_logs": {"privileges": "all"},
"saml": {"privileges": "all"},
"team": {"privileges": "all"},
"package": {"privileges": "all"},
"custom_roles": {"privileges": "all"},
"api_clients": {"privileges": "all"},
"oem_vendor": {"privileges": "all"},
"workspace_settings": {"privileges": "all", "enable_for": "non_oem"},
"environment_settings": {"privileges": "all", "enable_for": "non_oem"},
"oem_admin_settings": {"privileges": "all", "enable_for": "org_admin_with_settings"},
"oem_customer_settings": {"privileges": "all", "enable_for": "org_customer_with_settings"},
"logging_service": {"privileges": "all"},
"general_provisioning": {"privileges": "all"},
"account_deletion": {"privileges": "all"},
"disable_two_fa": {"privileges": "all"},
"configurable_data_retention": {"privileges": "all"},
"extended_60_days_data_retention": {"privileges": "all"},
"extended_data_retention": {"privileges": "all"},
"cmk_management": {"privileges": "all"},
"external_secret_sources": {"privileges": "all"},
"federation_management": {"privileges": "all", "enable_for": "federation"},
"scim": {"privileges": "all"},
"oem_ac_customers": {"privileges": "all", "enable_for": "oem_admin"},
"oem_ac_automations": {"privileges": "all", "enable_for": "oem_admin"},
"oem_ac_analytics": {"privileges": "all", "enable_for": "oem_admin"},
"usage_insights": {"privileges": ["read", "create", "update", "delete"]},
"usage_dashboard": {"privileges": ["read"]},
"cbp_usage_dashboard": {"privileges": ["read"]}
}Migrate a custom role
Converts legacy custom roles into environment and project roles. Alternatively, you can use the in-app migration wizard to migrate custom roles.
bash
POST https://YOUR_DATA_CENTER/api/roles_migration/custom_roleRequest body
| privilege_group_id | integer required | The ID of the role to convert. |
| environment_role | object required | Defines the environment role to create. |
| environment_role[name] | string required | The name of the new environment role. |
| environment_role[additional_permissions] | object optional | Specifies additional permissions for the new environment role. |
| project_role | object required | Defines the project role to create. |
| project_role[name] | string required | The name of the new project role. |
| project_role[additional_permissions] | object optional | Specifies additional permissions for the new project role. |
Sample request
shell
curl -X POST 'https://YOUR_DATA_CENTER/api/roles_migration/custom_role' \
-H "Authorization: Bearer <api_token>" \
-d '{
"privilege_group_id": :privilege_group_id_value,
"environment_role": {
"name": ":environment_role_name",
"additional_permissions": :environment_additional_permissions
"project_role": {
"name": ":project_role_name",
"additional_permissions": :project_additional_permissions
}'Response
json
"data": {
"name": "New Environment role",
"config": {
"lookup_table": {
"privileges": ["create", "access_control"]
"project_roles": [
"name": "New project role",
"config": {
"recipe": {
"project_administration": {
"privileges": ["access_control"]
"collaborators": [
"user_id": 1,
"name": "Yuri",
"roles": [
{ "environment": "dev", "name": "New Environment role" },
{ "environment": "prod", "name": "New Environment role" },
{ "environment": "test", "name": "New Environment role" }
"projects": [
"id": 1,
"collaborators": [
"user_id": 1,
"name": "Hao",
"project_role": "New project role"
"moderators": [
"user_id": 1,
"name": "Lucian",
"environment_role": "New Environment role",
}Last updated:
