# Remove user action
Remove a user from the Workflow apps portal. Refer to the App-user and group management guide to manage app-users in the UI.
Input field | Description |
User email | Provide the email of the user you plan to remove from the Workflow apps portal. |
Output is dynamic and may vary depending on the actions and triggers in your recipe, as well as the columns present in your Workflow app's corresponding data table.
To use this data in downstream steps, map in the relevant datapill from the datatree.
Output field | Description |
Success | Whether the user is deleted successfully. Available values include True or False . |
Last updated: 9/11/2025, 7:19:35 PM
