# Access the developer portal
The developer portal provides everything you need to discover, test, and consume APIs through a streamlined interface. This guide outlines the full client journey, encompassing everything from accepting an invitation to the portal to managing API keys and testing endpoints.
# Invitation and first-time login
When an admin invites you to the developer portal, you receive an email containing a secure, time-sensitive link. This link remains valid for 24 hours for first-time logins and 30 minutes for subsequent logins.
You can log in to the developer portal whether you’re accessing it for the first time, returning to the portal, or requesting a new link after your initial one has expired:
After logging in, you can proceed to Navigate the developer portal.
The portal dashboard serves as your central hub for managing API collections and interacting with endpoints. It provides the following key functionalities:
  • Browse API collections: View your assigned API collections, including details such as methods, parameters, and statuses for each endpoint.
  • Discover new APIs: Explore additional available API collections and request access to new APIs directly through the portal.
  • Test endpoints: Validate API functionality by sending requests and reviewing responses directly within the portal.
  • Manage and create API keys: Generate API keys to authenticate requests, define security parameters, and manage existing keys.
# Browse API collections
In the My APIs tab, you can access your assigned API collections. Selecting a collection opens its documentation, where you can explore endpoint methods, descriptions, and schemas. The documentation includes example requests and responses, where you can also download the OpenAPI specifications.
Browse API collections Browse API collections
# Discover new APIs
The Discover new APIs tab provides access to additional API collections. You can explore these collections to identify APIs that align with your requirements, and request access directly through the portal.
# Request access to new APIs
Complete the following steps to request access to new APIs:
Go to the Discover new APIs tab to browse available API collections.
Discover new APIs Discover new APIs
Select the collection you plan to access and click Request access.
Request access to an API collection Request access to an API collection
Provide a reason for your request and click Send request. An admin reviews your request and determines whether to approve or reject it.
Request access Request access
If the request is approved, the requested APIs appear in your My APIs tab, granting you access to their endpoints and documentation.
Collection added to My APIs Collection added to My APIs
# Test endpoints
The portal allows you to test API endpoints directly to validate their functionality. If you do not already have an API key, you must create one to generate the required authentication token before testing.
Complete the following steps to test an endpoint:
Go to your assigned collection in the My APIs tab and choose the endpoint you plan to test.
Click Try it out to open the testing interface.
Try out endpoint Click Try it out
Click Execute to send a test request.
Execute endpoint Click Execute
Review the response details, including status codes, headers, and payloads, to confirm the endpoint’s behavior.
# Manage and create API keys
The Manage API keys page allows you to manage your credentials. You can create and manage API keys and define security parameters such as allowed and blocked IP addresses.
Complete the following steps to create an API key:
Click Manage API keys in your profile drop-down.
Manage API keys Manage API keys
Click Create API key.
Create new API key Create new API key
Provide an API key name in the dialog.
Create new API key Provide an API key name
Optional. Specify Allowed IPs to restrict requests to specific IP addresses for enhanced security.
Optional. Add Blocked IPs to prevent requests from specific IP addresses. Blocked IPs take precedence over allowed IPs. For example, if you add the IP address 123.456.123.456 to your allow list, but also block it, users who attempt to access the portal from this IP address are denied access.
Click Generate to create the API key. The system displays the authentication token. Save this token securely, as it doesn’t display again. You must refresh or create a new API key if you lose it.
After creating the key, it appears on the Manage API keys page. You can use this page to view the token’s details or refresh, deactivate, or delete the key if required.
Last updated: 2/24/2025, 9:05:07 AM
