# Custom Domain
Route Workato API endpoints through your own domain to expose Workato API endpoints under your own subdomain. For example, modify the endpoint to reflect your company's subdomain.
Original API URL: https://apim.workato.com/boltco/sales-api/get-invoice
Custom domain URL: https://api.boltcompany.com/sales-api/get-invoice
NOT CASE SENSITIVE
Custom domains in Workato are not case sensitive.
# Configure a custom domain
VIRTUAL PRIVATE WORKATO (VPW) CUSTOMERS
This feature requires configuration steps that are specific to your Virtual Private Workato (VPW) instance. If you are a VPW customer, refer to your VPW private documentation for the configuration details for your instances.
Prepare a registered domain and subdomain name. For more information on domain names, see the ICANN documentation (opens new window). For example, blog.boltcompany.com.
Go to Platform > API Platform > Settings > Custom domain and click Add domain.
Register custom domain Register custom domain
Enter your subdomain name and click Add domain.
Register a domain Register a domain
Next, verify your custom domain by configuring the CNAME record with your domain host. The following steps use Cloudflare as an example.
Click Add record, select CNAME as the type, and provide the subdomain name. In this example, we create the subdomain api for domain boltcompany.com.
Create CNAME record with Cloudflare Create CNAME record with Cloudflare
Copy and paste the unique target value from your Custom domain settings. Use this value for your CNAME record. For example, abcde123456.apim-custom.workato.com.
Copy the unique CNAME target from your Custom domain settings Copy the unique CNAME target from your Custom domain settings
Click Save.
Depending on the domain host, it might take up to an hour for the new CNAME record to propagate through the global domain name system. After verifying your custom domain's DNS, Workato will start generating a TLS certificate. It can take up to an hour for the certificate to be issued and ready for use. Refresh the Custom domains page to check on the status.
Completed custom domain setup
CAN THE ORIGINAL ENDPOINT NAME BE USED?
  • The original API endpoint continues to work in parallel with your custom domain.
  • Requests to custom domains are routed to a specific set of IP addresses.
# Certificate for TLS
The default domain is workato.com when you use Workato’s API platform. Custom domains are supported. New certificates are created automatically when you add a custom domain. Workato manages API certificates to enable HTTPS on the custom domains that you add.
# Certificate renewals
Custom domain certificates automatically renew one month before the set expiration date. Workato manages the renewal process with Let’s Encrypt (opens new window). The new certificate request for the custom domain includes validating domain ownership through DNS records or other verification methods specified by Let’s Encrypt. Workato automatically deploys the new certificate after it is issued by Let's Encrypt. This seamless transition ensures that your custom domain continues to operate over HTTPS without interruption or manual intervention required on your end.
CERTIFICATE AUTHORITY AUTHORIZATION (CAA) RECORD
If you restrict the Certificate Authorities (CAs) that are allowed to issue certificates for your site, the custom domain workflow fails when trying to issue a certificate for your custom domain. Add a CAA record for Let's Encrypt's domain name letsencrypt.org to resolve this. Find out more (opens new window).
# Remove custom domain configuration
You may have to remove the current custom domain configuration if you would like to reconfigure your API platform to a different custom domain.
Click Remove on the top-right of the screen.
Custom domain pageCustom domain page
Read the notes on the remove custom domain wizard. Tick the checkbox and select Remove Domain.
Remove custom domainRemove custom domain
Now your APIs will default to apim.workato.com. Next, inform the existing users of this API collection, if you have not already done so.
Last updated: 5/29/2025, 2:19:46 PM
