# API Recipes - New API Request Trigger
This trigger creates a new API endpoint and runs when a new API request is received. Once configured, the endpoint can be called in other recipes or third-party systems as an API Platform endpoint.
# Requirements
To use this trigger, you need:
- Access to the API Platform feature. If you don't see this option in the Tools menu, reach out to your Customer Success Manager.
The New API request trigger has two types of input fields:
- Request - Fields that define how requests sent to the endpoint are structured.
- Response - Fields that define the structure of responses the endpoint sends to requests.
# Input Request Fields
The fields in the Request section define how requests sent to the endpoint are structured.
| Field | Description |
| Content type | Defines the data format of the request. Choose `application/json`, `text/plain` or `multipart/form-data`. Use `multipart/form-data` to upload large attachments (up to 5GB). |
| Request header | Defines the parameters request headers must have. |
| Request schema | Defines the expected schema request bodies must have. |
# Processing Binary Content
Multipart data may contain binary data, including images and pdf files. You must ensure that these files are in utf-8 encoding format. Workato recipe string processing supports utf-8.
# Input Response Fields
The fields in the Response section define the structure of responses the endpoint sends to requests.
| Field | Description | ||||||||
| Content type | Defines the data format of the response. Defaults to JSON if left blank. | ||||||||
| Response header | Defines the parameters response headers will have. | ||||||||
| Responses |
Defines the possible responses to a request sent to the endpoint.
This field also has some additional sub-fields:
| Field | Description | ||||||||||||||
| Context | Metadata about the API request. This field also has some additional sub-fields:
| Request | Contains details about the request's content type and body. This field also has some additional sub-fields:
# Additional Resources
