# API platform by Workato - New API request trigger
The New API request trigger defines the request and response structure for a recipe endpoint and creates a job when it receives an API request.
ACCESS REQUIREMENTS
API recipes require access to the API Platform feature. Contact your Customer Success Manager if you don't have access to the Platform > API platform page in Workato.
Input fields in the Request section define the structure of API requests to the endpoint:
Input fields Description
Content type Defines the data format of the request. Choose application/json, text/plain or multipart/form-data. Use multipart/form-data to upload large attachments (up to 5GB).
Request header Defines the parameters request headers must have.
Request schema Defines the expected schema request bodies must have.
Input fields in the Response section define the structure of responses the endpoint sends:
Content type Defines the data format of the response. Defaults to JSON if left blank.
Response header Defines the parameters response headers will have.
Responses Defines the possible responses to a request sent to the endpoint.
This field has the following subfields:
Name The name of the response. For example: Unauthorized or Created
Code The HTTP status code to be associated with the response which identifies the type of response. For example: Unauthorized responses are associated with 401 status codes.
Schema Defines the expected schema response bodies will have.
PROCESSING BINARY CONTENT
Multipart data may contain binary data, including images and pdf files. You must ensure that these files are in utf-8 encoding format. Workato recipe string processing supports utf-8.
Output fields Description
Context Metadata about the API request.
Calling job ID The ID of the job associated with the request.
Calling recipe ID If called from a recipe, the ID of the recipe that sent the request.
Calling IP address The IP address of the client calling this recipe as an endpoint.
Access profile Details about the access profile used to perform the request.
API client Contains details about the API client used to perform the request.
JWT claims Only available if a JWT token is used. Contains details about the JWT claims used to authenticate the request.
Request Contains details about the request's content type and body.
Content type Applicable only if the request's Content type is Raw. The Content-Type header value from the request.
Request body (raw) Applicable only if the request's Content type is Raw. The full, raw body of the request.
Request body (JSON) Applicable only if the request's Content type is JSON. A JSON object containing all the fields defined in the Request schema.
# Additional Resources
Last updated: 11/21/2025, 4:58:25 PM
