# Community library best practices
Follow these best practices to use and share community assets in your workflows effectively.
# Installing assets
We recommend using the following best practices when installing platform assets from the community:
- Evaluate asset metrics: Assess assets by viewing the metrics on the asset landing page, such as the total number of installations and critical builder statistics.
- Evaluate asset's code or workflow logic: Always evaluate the quality of a connector's code before releasing it to your workspace. Releasing a connector allows anyone in your workspace to use it in recipes, so be sure to test its functionality and safety thoroughly. Similarly, make sure to evaluate the underlying workflow logic of community recipes before using them in your workspace.
- Test the asset: Test the asset before releasing it or using it widely in your workspace. You can test the functionality and security of community connectors through Workato's Test code tab, located in Tools > Connector SDK > Source code. Similarly, we recommend customizing community recipes and thoroughly testing them before using them in your workspace.
- Use Workato resources: If you encounter errors in integrations that use assets downloaded from the community, contact Workato support (opens new window) for guidance. Our support team can assess the points of failure, as well as reach out to the asset developer for clarification.
# Uploading assets
We recommend using the following best practices when sharing assets with the community:
- Scrub sensitive information from your source code: When building your connector, you may have hardcoded sensitive information such as OAuth client IDs and secrets or API keys. These credentials will be compromised if other users install your connector. Be sure to scrub these values from your code before listing your connector on the community library. Collect sensitive data from users with input fields instead of hardcoding it.
- Customize your asset listing: Use a clear logo, description, and tags to accurately convey your asset's purpose and functionality.
- Prepare informational content: Set users up for success by providing them with informational content about your asset. You can place links to documentation in the actions and triggers of your connector. Additionally, if you enabled Prevent direct installation when listing your connector, the landing page you link to should showcase the connector, highlight how users can reach out, and provide a clear path to your private sharing link.
- Provide contact information: Ensure your community profile includes a contact email or website so users can reach out with questions about your asset. You can update this information on the Workspace admin page.
- Provide community recipes: Upload recipes for your community connectors to help users get started.
