# SQL Server - Run custom SQL action
# Run custom SQL
This action lets you send a SQL string to the SQL Server instance to be executed. It can be used to execute Data Manipulation Language (DML) statements like INSERT, UPDATE, SELECT and DELETE, as well as Data Definition Language (DDL) commands, like CREATE, ALTER and DROP.
1 MB QUERY SIZE LIMIT
Starting 1 December 2025, the Run custom SQL action in this connector enforces a 1 MB query size limit. This change improves platform reliability, increases performance, and avoids large queries that overload database connections or impact upstream systems.
Unlike Select rows using custom SQL, this action is not optimized for easy configuration. For SELECT statements with many columns, use that action instead. Using custom SQL is a great way to improve recipe efficiency and balance load between Workato and your database. Find out more in our best practices section how to use custom SQL to make your recipes more efficient.
OPA required
This action requires a connection using Workato on-prem agent. Find out more about on-prem connectivity here.
Getting timeout error
During bulk load of large datasets, creating, and updating tables in a database may take a long time. It may cause the job to fail with a timeout.
Prevent timeout errors by running your custom SQL asynchronously. Learn more here.
# Input fields
| SQL | Required. Enter a valid SQL string to run on your SQL Server instance. Workato can execute multiple SQL statements, but only returns results from the last statement. Separate each statement with a ;.You can map datapills to execute dynamic SQL. Wrap datapills in single quotes ( ''). |
| Output fields | Define the columns returned by your SQL statement. You can configure the output schema manually or click Use SQL to generate it from a sample query. The Use SQL option only supports queries that begin with a SELECT statement. Queries that begin with WITH aren't supported and trigger a syntax error. Leave this field blank if you don't expect return values. |
# Output fields
| Rows | A list of rows returned from the SQL execution. The structure is defined by the Output fields input. This field appears as an array datapill in the datatree if the Output fields input is blank. |
| Rows affected | The number of rows inserted, updated, or deleted. Returns nil for SELECT statements. Returns 0 for DDL statements like CREATE TABLE. |
Size limit
There is a size limit of 50,000 rows when your custom SQL statement returns data.
# Run custom SQL asynchronously
After the custom SQL query begins processing, Workato will check in periodically to see if the query results are ready to be retrieved. When the results have been successfully retrieved, Workato will proceed to the next steps in the recipe.
# Why run asynchronously
When a large dataset is being uploaded (INSERT) or updated (UPDATE), the action may take a long time to respond. If it exceeds the timeout limit, it will cause the recipe to fail due to a timeout error.
Running the SQL query asynchronously allows you to execute queries on large datasets without worrying about the time out. Even if the action takes hours to process, the job will not time out.
ACTION REQUIRES AN ON-PREM AGENT
This action requires a connection using Workato on-prem agent. Refer to the On-premise connectivity guide for more information.
Run custom SQL (async) action
# Output fields
| Rows | List of rows returned from the SQL execution. The fields in this list are defined by the Output fields input field. If left blank, this row will be available in the datatree as an array datapill. |
| Rows affected | This is an integer value indicating the number of rows inserted/updated/deleted from the SQL string. When executing When executing a DDL (for example, creating a table), the value |
Size limit
Last updated: 12/2/2025, 4:16:32 PM
