NetSuite REST
NetSuite is an enterprise resource planning (ERP) and cloud business management software suite provided by Oracle. It offers comprehensive software solutions for organizations, including support for ERP/Financials, CRM, and ecommerce.
Workato's NetSuite REST connector enables you to communicate with NetSuite's REST APIs.
API version
The NetSuite REST connector uses the NetSuite REST API. Refer to the NetSuite REST API Browser for API reference.
NETSUITE VERSION BASED ON INSTANCE AVAILABILITY
The NetSuite connector automatically defaults to the version available for your instance.
Connect to the NetSuite REST connector
The NetSuite REST connector supports OAuth 2.0 machine-to-machine (M2M) authentication.
Learn how to connect to NetSuite.
Supported actions and triggers
The NetSuite REST connector supports the following triggers and actions:
CUSTOM FIELD IDENTIFICATION
Custom fields are distinguished by the control type color displayed in the drop-down menu. You can also identify custom fields by label, for example, if you select a field and a custom label appears beneath it.
color code control typeControl type color code
custom labelCustom label
