# Search entries action (Batch)
The Search entries batch action retrieves a list of Active Directory entries matching the criteria you specify and processes them in batches.
# Input fields
Input field | Description |
Sample entry DN | Specify the distinguished name (DN) of a reference entry. The action uses this entry’s attributes as a template to define sub-fields in the Search entries by field and retrieve values from matching entries. |
Limit | Enter the maximum number of entries you plan to retrieve for each action. The maximum is 1,000 entries. |
Search entries by | Enter values for each attribute you plan to filter by. Only entries that match all the provided values are processed. This field includes sub-fields for each attribute of the reference entry. |
Advanced search filter | Enter LDAP filters (opens new window) to define search conditions. For example, enter (ou=Dev)(objectClass=Person) to retrieve only Person entries from the Dev organization unit. |
# Output fields
The Search entries action's output is a list of entries that match your criteria, including their values for each attribute defined by the reference entry.
Last updated: 10/3/2025, 11:49:36 PM
