# Amazon SES Connector - Delete object
The Delete object action deletes an object in Amazon SES. You must select the object to delete and provide relevant input fields for that object.
| Object | Required. Select the name of the object to delete. You can choose from the following options:
| Status | Indicates whether the object was deleted. |
Last updated: 6/17/2025, 5:42:27 PM
