# Amazon SES Connector - Get object action
The Get object action gets an object in Amazon SES. First, select the object you plan to get. After selecting the object, fill in any relevant input fields related to that object.
| Object | Required. Select the object to retrieve. You can choose from the following options:
Object specific output fields will be dynamically rendered base on the objects you select.
Last updated: 6/17/2025, 5:42:27 PM
