# Amazon SES Connector - List object action
The List object action lists objects in Amazon SES.
| Object | Required. Select the object to list. You can choose from the following options:
| Page size | Select the number of objects to be returned in a single page. |
| Next token | Type a token indicating additional records exist when outputs exceed the current page size. You can use the token in another List object action to retrieve the next page of records. |
Object specific output fields are dynamically generated based on the objects you select.
Last updated: 6/17/2025, 5:42:27 PM
