# AWS Inspector2 - List findings action
The List findings action retrieves a list of findings in your environment. Findings represent potential security risks, such as vulnerabilities or misconfigurations, and include detailed information for remediation.
Input field Description
Filter criteria Define the search criteria for findings. You can filter by criteria such as severity, resource tags, and more. Refer to Amazon's Field criteria object (opens new window) guide for more information.
Max results Set the maximum number of results to return. A NextToken is returned for pagination if more results are available.
Page token Use this token to retrieve the next page of results. Set it to null for the first request. For subsequent requests, use the NextToken returned from the previous response.
Sort criteria Specify how to sort the findings. Specify the field to sort by and the sort order (ascending or descending).
Output field Description
Findings Contains details on the findings in your environment.
Next token Use this token to paginate results. Set it to null for the first request. For subsequent requests, use the NextToken from the previous response to retrieve the next page of results.
Last updated: 12/11/2025, 6:57:33 PM
On this page
