# Azure File Storage - Upsert file action
The Upsert file action enables you to create a new file or update an existing file with content you specify. The action searches your files and replaces your file content if it finds an existing file. The action creates a new file with the content if it doesn't find an existing file.
This action supports files up to 300 MB.
| File path | Enter the path to the file in the share, including the file name. For example, hrdata/test.csv |
| Timeout | Specify the timeout in seconds to wait for the server to complete the operation. |
| File contents | Specify the contents of the file. |
| Request headers (create file) | Specify HTTP request headers for the create file operation, such as content length, content type, cache control, and metadata. |
| Request headers (put range) | Specify HTTP request headers for the put range operation, such as content MD5, lease ID, file last write time. |
| Create file response | Output of the create file operation. |
| Status code | HTTP status code of the operation. |
| Response headers | HTTP response headers including content length, last modified, ETag, and request ID. |
| Put range response | Output of the put range operation. |
| Response headers | HTTP response headers including content length, content MD5, last modified, ETag, and request ID. |
Last updated: 9/17/2025, 8:53:38 PM
